Author Topic: Which Can-Bus?  (Read 1731 times)
Offline mkmg76
Which Can-Bus?
« on: July 13, 2017, 05:05:44 pm »
Ok, so I have upgraded to a Kenwood DNX525DAB and as far as I was aware, the Nav directions were supposed to show up on the highline display like my MFD2. They don't. Also it only says "ACTIVE" when you select Audio and doesn't show any other info.
Also, I hadn't driven the car for about 2 days and when I tried to start the car, it was lazy, indicating a low battery. I'm assuming since these are VW approved radios, they use the same Can-Bus functions as the RNS-510 and as such it's causing the same issue, i.e., battery drain.
As we all know, this is usually fixed by upgrading the Can gateway and with that, should (hopefully) give me my Nav instructions back on the highline screen. My question is which gateway do I need?
I've read that I need to change like for like apart from the revision letter at the end and that "L" is a minimum.
I've had a look online at a VW parts system, (I work in an aftermarket parts suppliers) and its giving me a part number of : 7N0907530BH - Diagnosis interface for data bus (Gateway), am I looking at the correct part?
Thanks for any help.
Mick.  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which Can-Bus?
« Reply #1 on: July 13, 2017, 06:27:02 pm »
Nav instructions on highline will only appear with oem units like an rns510.
Sent from my SM-G955F using Tapatalk
Offline Christiank
  • -Receive: 39
Re: Which Can-Bus?
« Reply #2 on: July 13, 2017, 06:44:55 pm »
Don't know anything about aftermarket units - But you can have my old Canbus "AN" for a good price. I did install this one when I bought a RNS315 to my mk5. I've got the AS version now since I installed the Discover Media 2 unit in my car.
Offline mkmg76
Re: Which Can-Bus?
« Reply #3 on: July 13, 2017, 08:09:19 pm »
Ah ok, I thought since it does everything else, i.e., visual parking, heated seat info etc, it may do that too. Its not a big deal. Thanks for the reply.  :happy2:
Offline mkmg76
Re: Which Can-Bus?
« Reply #4 on: July 13, 2017, 11:38:15 pm »
Shoot me a PM buddy with your price and exact part number please. I may well be interested in that.
