Author Topic: Millers Nanodrive Oil, which one ?  (Read 1703 times)
Liam0205
« on: July 14, 2017, 02:59:42 pm »
Hi
Is this the correct one for my Eddy
http://www.opieoils.co.uk/p-115238-millers-oils-nanodrive-cfs-5w-40-nt-full-synthetic-engine-oil-2017.aspx
I've been running with Nanodrive for about 3 years but the one I use to order doesn't seem available anymore, has the packaging just changed?
Offline colesey
  • -Receive: 89
Re: Millers Nanodrive Oil, which one ?
« Reply #1 on: July 14, 2017, 03:31:37 pm »
Yep that's the one I put into my car yesterday. Has recently changed to '+' spec. Don't forget to use your TFSI discount code!
Offline 19TW80
« Reply #2 on: July 14, 2017, 06:56:11 pm »
What's the discount code, @Liam0205 ? TIA.
Liam0205
« Reply #3 on: July 14, 2017, 08:23:27 pm »
No idea, what's the discount code?
Offline horsemeat
« Reply #4 on: July 15, 2017, 10:02:19 am »
I emailed them about this as I was also confused. Wanted to make sure I could top up with the older stuff once I had changed to the "+" version. Their reply was clear:
"Yes, the old version is fine to mix with it. The only real difference between the old and new versions is that the new one has a higher dose of the Nanodrive additive."
So essentially the same product. Hth
