Author Topic: HELP - fuel pump piston snapped  (Read 4102 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: HELP - fuel pump piston snapped
« Reply #15 on: July 18, 2017, 09:09:45 pm »
If refitting your engine cover then yes, you will need the sensor to sit at the right position
Offline Rigsby
  • -Given: 22
« Reply #16 on: July 18, 2017, 09:22:48 pm »
Yeah the engine cover will be going back on.
Anyone know why it won't tighten to 11 o'clock? Bizarre
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #17 on: July 18, 2017, 09:24:22 pm »
Because its a part thats not available separately and is not designed to be swapped and changed between pumps?
Offline Rigsby
  • -Given: 22
« Reply #18 on: July 18, 2017, 09:34:57 pm »
I guess the threads are slightly different between old and new hpfp.
As when I put the newer sensor in the old pump it ends up at 1 o'clock
Old sensor in new pump ends up at 1 o'clock
Put them Both back in it's original pump and they end up at 11 o'clock.
??? Driving me mad....suppose I'll just use the damaged/repaired sensor
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #19 on: July 18, 2017, 09:44:05 pm »
Oops
Offline Rigsby
  • -Given: 22
« Reply #20 on: July 18, 2017, 10:16:06 pm »
I've ordered a pressure release valve form vw as my pump didn't have one.
Hopefully pick it up and fit it all tomorrow. :stupid:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: July 18, 2017, 10:31:54 pm »
wondering why you didn't fit the complete replacement pump in?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #22 on: July 18, 2017, 10:35:06 pm »
I bought a good second hand pump.
It was the newer version without banjo fixing and the pressure release valve.
The top sensor was cracked and been repaired, was told it still works but looks nasty.
No problem I'll just swap the top sensor over from my old pump along with the banjo fitting, but I can't get the top sensor to sit at 11 o'clock like it should...ends up at 1 o'clock every time, anyone know why?
Dies the sensor need to sit at that angle?
just read what I missed, older one doesn't have a pressure release valve as it's an AXX engine code pump!!!
Who's sensor was repaired?, the used one :scared:
« Last Edit: July 18, 2017, 11:31:19 pm by r5gtt »
Offline Rigsby
  • -Given: 22
« Reply #23 on: July 18, 2017, 10:49:53 pm »
@r5gtt
My original pump has banjo and no pressure release valve.
The pump I bought has hose (no banjo) and a hole for a pressure release valve, and a cracked/repaired top sensor.
Hope that makes sense
Offline v4rley
  • -Receive: 104
« Reply #24 on: July 18, 2017, 11:08:40 pm »
So you brought a replacement pump with a broken sensor??
99% sure if you removed the 'bamboo' fitting on your replacement pump the bango bolt would have fit it the now vacant hole.
Ok just re read through. So basically you brought a pump with a broken sensor and are trying to replace the sensor from your original one with the snapped piston.
« Last Edit: July 18, 2017, 11:16:10 pm by v4rley »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #25 on: July 18, 2017, 11:29:33 pm »
@r5gtt
oh heck!!! I understand now but again why would you buy a pump with damaged sensor as you can get them for £50-60 in tact  :sad1: would have given you my internal FOC just postage but you'd laughed it off as you bought one  :doh:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #26 on: July 19, 2017, 11:56:40 am »
Just to jump in here, if anyone is selling a second hand pump fire me a PM :)
My sensor snapped, I repaired it, was ok for a while but didn't last... EPC light on again, limp mode.
@OP: I wouldn't trust the snapped sensor repair mate, if it does go it's like hitting a wall from WOT to Limp Mode, better safe than sorry  :happy2:
Offline colesey
  • -Receive: 89
« Reply #27 on: July 19, 2017, 02:16:18 pm »
I should have one available in next day or so as I am having to replace due to the piston staring to crack. Sensor is fine if you wanted to rebuild yours with the parts
Offline Rigsby
  • -Given: 22
« Reply #28 on: July 19, 2017, 08:48:02 pm »
All done folks, drama over.
I'm going to get an intake next and get rid of the engine cover, then I can put my other sensor on top. If id of used it now i think the engine cover would of broke it due to the fact the it sits at the wrong angle when installed in the new hpfp
