Author Topic: Does bluetooth need highline dash?  (Read 2787 times)
Offline jedi-knight83
  • -Receive: 41
« on: July 17, 2017, 09:51:28 am »
 Where is Eddie_NL these days? He used to be the master of these things.
I think I've screwed up. Its for my wife Polo but I know things are pretty interchangeable so I'm guessing the same principals apply?
She's got the RCD510 head unit and the bury bluetooth that sits on the dash. I bought the proper 7P6 J revision bluetooth module and loom and was planning on installing that so she can also stream music but I've suddenly though that she probably needs the highland clocks as well so she can connect the phone etc??
Is there any way to do it without this?
If not... I need to buy a highland clock.. anyone on here that can code it in Eddie_NL's absence?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Does bluetooth need highline dash?
« Reply #1 on: July 17, 2017, 10:52:45 am »
What I normally do when my phone can't find the 7p6 units is use vcds to clear all the old profiles from the unit, unplug the unit and plug back in. Then do a search to pair it.
What happens when you press phone button on the rcd 510
You won't need highline dash for it. Can all be done from phone and controlled from rcd or rns.
Sent from my SM-G955F using Tapatalk
  • -Receive: 41
« Reply #2 on: July 17, 2017, 11:00:33 am »
Ah brilliant news.
I've not actually fitted it yet. I was going to do it tonight but just suddenly thought about the highline dash on the way to work this morning and got worried it wouldn't work.
willni
« Reply #3 on: July 17, 2017, 04:37:30 pm »
Ah brilliant news.
Can't really comment, but I had the rcd510 and bury running in my polo at the same time with no trouble. But I'm sure you know the polo is very user friendly so you should be able to just operate it through the rcd510.
https://uk-polos.net/ Has a very very good network of electrical modification if you ever need guides etc
Edit;  never mind just saw you posted on it  :ashamed:
