Author Topic: Can your Maxidot/Highline do this  (Read 7382 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Can your Maxidot/Highline do this
« Reply #15 on: February 05, 2010, 09:36:12 pm »
ive never seen this before, nice mod mate  :happy2:
whats involved in fitting it??  eg. clocks out/ dash in bits etc
Cable to be fitted behind radio, very easy DIY
Over the top mod list ;o)
Offline v2brett
« Reply #16 on: February 05, 2010, 09:42:39 pm »
thanks for that,but  now i have another Q   will this work with the Blaupunkt PnP system i have fitted.
think this may be my next mod  :jumpmove:
Still Here!
  • -Given: 243
  • -Receive: 154
« Reply #17 on: February 05, 2010, 09:52:08 pm »
i can't see why not, it's to be fitted between you original wiring and aftermarked wiring, if you wait a week  mine might be for sale as i'm not sure it fits with my BT kit
Offline v2brett
« Reply #18 on: February 05, 2010, 09:58:33 pm »
ok danish thanks for the info,  and yeah i can wait a week PM me when you know if it fits or not
Still Here!
Offline mortygttdi
  • -Receive: 146
« Reply #19 on: February 05, 2010, 10:39:27 pm »
does't work with the plug and play bluetooth
Darren
  • -Given: 243
  • -Receive: 154
« Reply #20 on: February 06, 2010, 06:18:43 am »
Darren
i knew it, why does it have to be so complicated, well then i have an E-MFA for sale  :sad1:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #21 on: February 06, 2010, 08:25:20 am »
I don't think the E-MFA works on it's own. I think you have to have the Fiscon Kit aswell.
The kit I fitted was the Fiscon Basic Plus kit. Everything you require is in the box.
Basically pull MFD3/Stereo out undo quadlock. Connect that to cable provided. Plug other end into stereo/MFD3 and then the two cables that branch off the loom one goes to the black fiscon box the other goes to the microphone.
The last thing you then need to do is using VCDS Select block 19 Can Gateway. Click coding then on byte 3 tick bit 7 (telephone) and that's it.
All done and if you have the MFD3 everything can be done from the touchscreen exactly as you can with OEM Bluetooth.
Good thing with this kit though is you can read texts that come through and reply to them ( with the preset replies most phones have ). You also with the plus kit get the E-MFA included
You can also use the steering wheel controls if you have MFSW or the wiper stalk. Also in a golf you can use the microphone for voice activation ( it doesn't in Skoda but I'm working on that )
I will do a proper thread later on today but suffice to say I'm mega chuffed with it.
Carl :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #22 on: February 06, 2010, 08:53:22 am »
Carl :happy2:
this is the stand alone cable, not the part of fiscon bt solution.  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #23 on: February 06, 2010, 08:55:56 am »
Ahh that will be why it works then  :grin:
Carl :happy2:
