Author Topic: Rns 315 Bluetooth display on mfd  (Read 6673 times)
Offline toplad
« on: July 22, 2017, 07:44:50 pm »
I'm just wondering if you can use the phone buttons to bring the phone menu on the mfd.
I've just installed an RNS 315 and it doesn't show up any phone menu's  on the mfd, I think it's coded properly as everything works as it should, compass, nav, song's etc.
I have a 2010 scirocco R which previously  had an RNS 310
Offline toplad
Re: Rns 315 Bluetooth display on mfd
« Reply #1 on: July 25, 2017, 12:50:02 pm »
No one?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: July 25, 2017, 01:20:40 pm »
the phone button should answer and hang up calls, To get the menu Im sure you use the MFD screen menus
Offline toplad
« Reply #3 on: July 26, 2017, 08:06:29 am »
Thanks Raz
The phone button works properly, no phone menu's on the mfd though
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #4 on: July 28, 2017, 11:29:14 pm »
rns315 work on BAP system so they wont display on mk5 red display clocks but will work on scirroco & mk6 clocks as they use BAP & it will need coding in vcds.
« Last Edit: August 07, 2017, 10:24:40 pm by mrxbox360 »
Offline Pashka
« Reply #5 on: August 02, 2017, 06:55:40 am »
rns315 work on BAP system so they wont display on red clocks but will work on scirroco - mk6 clocks as they use BAP & it will need coding in vcds.
mk6 doesnt have red cluster  :happy2: Just need to code it as navigation on the gateway if upgraded from the radio.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline mrxbox360
« Reply #6 on: August 17, 2017, 12:06:15 am »
ive amended my post
