Author Topic: Pre-Map Preparation  (Read 3892 times)
Offline Cadders96
Pre-Map Preparation
« on: July 25, 2017, 02:56:32 pm »
I am getting my car mapped on the 11th August and I was wondering what preparation I need to do in advance, I have done an oil change to 5W40 already on Saturday and the Cam Follower was changed about 3/4 months ago. Any thing important I need to do before I get it mapped? Ta
EDIT: Only going for a custom map would be around stage 1ish map at Badger5 (Have had good feedback from friends about this place)
« Last Edit: July 25, 2017, 02:58:15 pm by Cadders96 »
VW Golf GTI Mk5 3 door
18" Monzas
Tinted Windows
Powervalve WRC Sports Cat-Back Exhaust with Decat Downpie 3" (Ebay Special)
Climair Wind Deflectors
HID Foglights
GFB DV+
Pre-Cat Delete
Offline colesey
  • -Receive: 89
Re: Pre-Map Preparation
« Reply #1 on: July 25, 2017, 03:28:12 pm »
Suggest you check the pcv and DV also.
Offline Cadders96
« Reply #2 on: July 25, 2017, 03:42:49 pm »
Best way to check PCV? And I got a GFB DV+ couple months ago as well
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: July 25, 2017, 03:48:11 pm »
You can do the dip stick removal test. Personally I don't think it actually is a good indicator.
PCV is cheap, replace it for peace of mind!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: July 25, 2017, 04:03:17 pm »
Full tank of V power!
Pre-cat delete, not a must but R Tech asked me if mine was removed before I went Stage 1 with them
« Reply #5 on: July 25, 2017, 04:31:31 pm »
Plugs if they're old, MAF if it's old, boost pipe bayonet O rings if they're old and leaking etc etc
You should get a good map from Mr Brockbank..... he's been in the game a long time!
Offline wrlcs
« Reply #6 on: July 25, 2017, 05:44:22 pm »
From m experience, coil packs if old.
Offline grey golfster
  • -Given: 79
« Reply #7 on: July 25, 2017, 06:53:24 pm »
Well, sorry to be a grumpy old fart, but the first thing I would do would be a search of this website.......then come back with your questions, once you've had a bit of a read-around?
Here's one I found in about 5 seconds.
http://www.mk5golfgti.co.uk/forum/index.php?topic=55886.0
Does no one search any more?
This is not facebook...TF!  :slap:
Offline Cadders96
« Reply #8 on: July 31, 2017, 08:49:36 am »
Got the Pre Cat Delete already, bought the car over a year ago an decided to check if it was there or not couple months ago and well it wasn't. Nearest Shell V Garage and Tesco Momentum are both 25/30 mins away so don't fancy that when I need petrol locally would be pointless doing a 50-60 min round trip for that. Whats next best, theres BP Super Unleaded, Sainsburys Super Unleaded and Esso super unleaded by me what would be best?
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: July 31, 2017, 09:06:30 am »
Only other fuel i have ever put in was BP premium and that was because it was xmas day and shell was closed lol. Still drove ok.
Sent from my SM-G955F using Tapatalk
« Reply #10 on: July 31, 2017, 09:35:08 am »
Those 3 are only 97 RON, so you'll be timing limited.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #11 on: July 31, 2017, 01:43:05 pm »
Speak to Bill about that ^ OP.
If it's mapped on 97 you'll be fine running it on BP Ultimate etc.
I had no choice but to use 97 once to get me home (R-Tech map, so needs 99) and it was noticeable.
  • -Given: 79
Re: Pre-Map Preparation - Maps to RON
« Reply #12 on: July 31, 2017, 07:45:02 pm »
I seem to spend a relatively large amount of time where there are no Shell supplies ( > 17 miles from home), Tesco much easier tho.
One of the reasons that I chose an APR map is that it has 4 "settings" (including standard & Valet - albeit valet parking not an issue that I face in my life!) these modes are readily switchable using the cruise control stalk and a PIN code.
I can also choose to switch down from "Max Power"/99 RON back to standard, allowing me to operate safely in areas where the higher RON fuel is not available.
However, I am finding that this is becoming less of a problem as time goes on; you can usually find either Tesco or Shell on, or fairly close to motorways in most places. I have mostly been running on Tesco Super ("Momentum Plus"?) as it's quite a bit cheaper, and much more readily available. No issues at stage 2 n a bit with Lobba HPFP.
I am not getting drawn into the "who's the best map" debate - just sticking to practicalities for a daily Driver.
« Last Edit: July 31, 2017, 07:46:36 pm by grey golfster »
« Reply #13 on: August 01, 2017, 09:19:45 am »
A tune for 95 unleaded vs 99 is only about 20hp down at Stage 1 levels, perhaps a bit more at higher boost pressures.
Anyway, I've been using Tesco 99 more and more lately as it's 20p a litre cheaper than V Power where I live.   I never understood how petrol companies could get away with charging more for the same thing, depending on region, but they have ~20 years left and they're gone, and good riddance.
Offline Cadders96
« Reply #14 on: August 01, 2017, 10:04:30 am »
I was gonna use Esso Super Unleaded which is 97 I believe, if I had either a Shell V or Tesco Momentum in town I would definitely only be using them but I don't unfortunately.
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
