Author Topic: Single knock from front  (Read 1520 times)
Offline Stupots
  • -Given: 18
« on: July 27, 2017, 06:49:15 am »
I've had this for a while now. When I am on near full right lock (doing a 3 point turn or pulling into a car park bay) I get a single clunk from the front as I straighten up. This happens I suppose just before the wheels are nearly straight. Is this the common steering rack issue? Could it be the circlip has failed on the end of the drive shaft and is popping out/in the hub? does anyone have any other ideas?
I went to my local MOT centre and asked them to pop it up on their ramps and give the front suspension a proper going over and everything was spot on, so I don't think it's a failed bush/track rod end/etc.
Thoughts?
Stu
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Single knock from front
« Reply #1 on: July 27, 2017, 08:09:11 am »
Sounds to be more like broken spring.
They break at the top, so can't easily see right up the top of the 'tube' shape
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline Stupots
  • -Given: 18
« Reply #2 on: July 28, 2017, 06:32:26 am »
Cheers Ady, I'll have a look tomorrow while I'm doing an oil change. I did replace the shocks/springs last year with new standard OEM so hope it's not that, though with give me an excuse to go with a VWR setup :)
