Author Topic: FK highlines  (Read 729 times)
Offline eb198
FK highlines
« on: August 04, 2017, 06:13:00 pm »
Iv fitted a pair of fk highlines to my gt tdi. Iv only set them to minimum lowering (30mm) with 15mm spacers. The fitment is spot on but the ride is very soft, keeps scrubbing the arches. Does anyone know if you can adjust the damping on them or are they fixed?
Regards
Re: FK highlines
« Reply #1 on: August 04, 2017, 06:35:40 pm »
Think they're fixed.   You'll have to remove the spacers, mod the arches or fit stiffer springs.
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
Re: FK highlines
« Reply #2 on: August 04, 2017, 09:37:08 pm »
Are the Highlines the same as the Silverlines? If so, they are damping adjustable, they're Koni dampers.
Offline jaffa
  • -Receive: 44
Re: FK highlines
« Reply #3 on: August 04, 2017, 10:04:00 pm »
The only fk coilovers that have adjustable dampening are the silver line x coilovers so if you haven't got them then you have no dampening adjustment if you want a stiffer ride you'll have to lower it more
