Author Topic: Mk6 tsi abs pump coding  (Read 6113 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: August 04, 2017, 11:35:43 pm »
Is it easy to code the abs pump as the ecu fried to ecu and clock were replaced car starts but flashing hand brake and esp lights now?.
Offline SI-R32
  • -Receive: 125
Re: Mk6 tsi abs pump coding
« Reply #1 on: August 05, 2017, 08:33:49 am »
Do you have any existing scans/coding from the car?
If not you might find it hard to do, do you know what abs module you have fitted to the car?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: August 05, 2017, 03:44:26 pm »
I'll have to ask him if he saved it mate, no idea what abs module it is as it's not been taken out
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: August 07, 2017, 02:08:49 pm »
Hi @SI-R32 I saved the code in my laptop as the other guy who came out replaced ecu and clock didn't program the abs.
Can I program this with vcds ?
Looks like I didn't save the abs data after all  :doh: it was ecu data
« Last Edit: August 07, 2017, 04:06:42 pm by r5gtt »
Offline SI-R32
  • -Receive: 125
« Reply #4 on: August 09, 2017, 10:48:26 pm »
Sorry for massive late reply, what is vcds telling you your brake unit is, mk60ec1? Mk60, Mk70? Pop into module 3 abs and it should tell you, then we can proceed from there
« Last Edit: August 09, 2017, 11:01:20 pm by SI-R32 »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: August 10, 2017, 09:21:33 am »
No worries Si, I understand you're busy unlike some of us who have no life lol  :signLOL: sorry private joke as I'm suffering with chronic nerve pain.
I'll have another look and let you know thanks
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: August 10, 2017, 12:39:31 pm »
Hi Si, it's an mk60ec1 thanks
Offline SI-R32
  • -Receive: 125
« Reply #7 on: August 10, 2017, 01:07:17 pm »
So could be a nightmare, have you any saved scans of your car from vcds?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: August 10, 2017, 04:30:02 pm »
Not looking good then but here you go. Fitted with a used ecu, cluster and body control module. The chap who came out with his software got the car started but cannot code the ABS as the coding ATM looks like 000000000000000000
« Last Edit: August 10, 2017, 06:32:14 pm by r5gtt »
Offline SI-R32
  • -Receive: 125
« Reply #9 on: August 10, 2017, 04:43:09 pm »
Because I've got your vin and abs module part number I might with a couple more details like brake disc size and stuff make up a code for you, It'll be tomorrow though as on nights
Offline SI-R32
  • -Receive: 125
« Reply #10 on: August 10, 2017, 04:45:08 pm »
It's also really good you only have 1 fault of not coded, so you should just be able to bang in a code tomorrow once I get a few more details
Just fyi for anyone reading this in the future, always scan your car whether new or old save a complete scan somewhere safe, it may just get you out the sh*t in the future
« Last Edit: August 10, 2017, 04:47:24 pm by SI-R32 »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: August 10, 2017, 05:50:37 pm »
That would be awesome  :jumping:
Would I need to give you these details of the discs etc mate?
Offline doylebros
« Reply #12 on: August 10, 2017, 06:00:23 pm »
The build sticker in the boot or service book with the codes on might save you a bit time if you send SI that.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: August 10, 2017, 06:29:55 pm »
Thank you  :smiley:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: August 11, 2017, 10:44:36 pm »
Update to this:
With the help of @SI-R32 I've managed to code the used donor abs pump for this tsi mk6
Previously hand brake, ABS as traction control were flashing but have now stopped flashing. Only things left are the tc and abs are at a solid state and we believe needs basic settings carried out.
Thanks again SI  :drinking:
« Last Edit: August 11, 2017, 10:57:09 pm by r5gtt »
