September 28, 2024, 04:33:05 pm
All Things Mk5
Mk5 General Area
Water pump replacement
Topic: Water pump replacement (Read 1156 times)
CaulkheadVW
Can't Read PM's Yet!
-Given: 4
-Receive: 0
August 07, 2017, 07:01:28 pm »
The cam belt and tensioner were replaced on my 2007 Mk5 at 52000 miles according to the service record but not apparently the water pump. Car is now on approx. 79000 miles so I guess the pump is overdue do I need to replace belt again?
99hagued
Always Involved
-Given: 5
-Receive: 23
Re: Water pump replacement
Reply #1 on:
August 07, 2017, 08:12:54 pm »
I don't think there is a replacement interval on the water pump just recommended to be changed with the belt. If it's not leaking I would just change it next time the belt is due which is every 4 years.
https://i.imgur.com/CGZ3DaG.jpg
Dan_FR
Just look at my post count
-Given: 132
-Receive: 189
wait...what?
Reply #2 on:
August 08, 2017, 07:38:07 am »
Car should have had two belts by now... Is it not overdue a second? I'd get the pump replaced at the same time as the belt unless you get any symptoms before hand
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
All Things Mk5
Mk5 General Area
