Author Topic: Clutch and DMF Replacement  (Read 3198 times)
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
« on: August 15, 2017, 08:49:23 am »
Hi does £720 all in sound about right for a new OEM clutch, DMF, Slave cylinder and all bearings on my Edition 30?
Ta
Dean
Offline Cadders96
Re: Clutch and DMF Replacement
« Reply #1 on: August 15, 2017, 09:14:39 am »
£800 at AKS tuning for a uprated clutch and OEM flywheel, have heard this is the one to go for and I am buying this later today, comes with
Helix Organic Or Paddle Drive Plate
Helix Billet Clutch Cover
LUK Slave Cylinder (Bearing)
AKS Custom Cover Genuine Bolts
LUK Flywheel And Flywheel Bolts *Optional* (When buying Flywheel)
VW Golf GTI Mk5 3 door
18" Monzas
Tinted Windows
Powervalve WRC Sports Cat-Back Exhaust with Decat Downpie 3" (Ebay Special)
Climair Wind Deflectors
HID Foglights
GFB DV+
Pre-Cat Delete
« Reply #2 on: August 15, 2017, 09:20:35 am »
Thanks for response
The £720 was a fully fitted and warrantied price I guess the gear your referring too is supply only?
If so how much do you expect to pay for fitting or are you planning on fitting yourself?
Tx
Dean
Offline rcrmn
« Reply #3 on: August 17, 2017, 09:00:56 pm »
Hey Dean,
The garage that I usually use charged me £200 cash for the fitting of my Clutch, Flywheel and Release Bearing that I'd already bought from Darkside here
I'd say around £200/£250 for fitting is usually around what it should be if you're supplying the parts :happy2:
« Reply #4 on: August 21, 2017, 08:42:23 am »
Spot on then parts are £520 trade from MVC so £200 fitting costs:-)
TX
Offline Cadders96
« Reply #5 on: August 21, 2017, 09:01:30 am »
Hey Dean,
Does this include fluids or did they supply this?
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
« Reply #6 on: August 21, 2017, 10:16:40 am »
Fluids including in fitting:-)
