Author Topic: Not clued up on exhausts and needing help  (Read 6524 times)
Offline Dave_d
« on: August 15, 2017, 05:55:03 pm »
Hi guys, I took my car to the garage earlier to get a mechanic to check over the exhaust as it sounds like a tractor! It turns out the flexi in my downpipe is blowing very badly, so will need to be replaced.
Currently it has a standard downpipe and cats which then go into a  3"stainless cobra exhaust, I've decided I'm going down the de cat route so I need a decat pipe to replace my current. I've found this but I'm unsure if it will fit? Wil it need adaptors or anything?
https://www.ebay.co.uk/itm/162590892180
Really appreciate any help you can give me. Need to get it sorted asap as my car sounds awful
Dave
Offline Shoy1980
Re: Not clued up on exhausts and needing help
« Reply #1 on: August 15, 2017, 06:27:39 pm »
Before you proceed please bare in mind that a decat will fail MOT
Offline Dave_d
« Reply #2 on: August 15, 2017, 07:18:35 pm »
Yeah I know cheers shoy  :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: August 15, 2017, 07:34:07 pm »
It looks to fit a MK5 gti, but you won't need the transfer pipe they give you. It looks to be for running the oem stock exhaust as it goes from their DP diameter to a smaller bit. So, in addition to that DP you'll need a section to connect the DP to your exhaust. You may want an 90° angled O2 spacer. I am catless as well and my CEL was always on until I installed one. Got one off ebay for $15usd.[ https://www.google.com/search?q=angled+o2+spacer&source=lnms&tbm=shop&sa=X&ved=0ahUKEwiDxJum79nVAhVKVWMKHRirD_EQ_AUICigB&biw=1173&bih=529 ] Aim it so the O2 is upstream and slightly elevated North of horizontal...mine ↓
« Last Edit: August 15, 2017, 07:35:57 pm by ROH ECHT »
Offline Dave_d
« Reply #4 on: August 15, 2017, 07:49:03 pm »
Sorry to sound simple, what is a transfer pipe  :confused: my cars had a map so it's had the eml erased according to a guy I took my car to rolling road.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 79
« Reply #5 on: August 15, 2017, 11:20:34 pm »
Should do, as your cobra catback is already mated to the standard downpipe. Get a pic up of the cobra and can tell you if it'll defo fit
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #6 on: August 16, 2017, 09:37:35 am »
It is the second pipe in the pic of the DP in question you gave the link to... and it is just a nearly straight section reduced at one end for oem sized exhaust fitment...goes between the DP and catback. Why i said won't need it due to your existing 3" catback. Probably need that section made to fit what you got. Likely can be stretched back out to 3" and add a v-band or whatever is at the upstream end of your 3" catback.
Great, no need for the O2 spacer then.  :drinking:
« Last Edit: August 16, 2017, 09:45:28 am by ROH ECHT »
Offline Dave_d
« Reply #7 on: August 16, 2017, 12:27:19 pm »
this is a picture of my stainless box into my standard downpipe
« Last Edit: August 16, 2017, 12:28:56 pm by Dave_d »
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 79
« Reply #8 on: August 16, 2017, 01:02:57 pm »
It'll fit, just use the existing clamps
Offline Dave_d
« Reply #9 on: August 16, 2017, 01:12:02 pm »
Cheers boss  :happy2: I'll order it
Offline Dave_d
« Reply #10 on: August 16, 2017, 02:51:10 pm »
Ordered it, will be delivered Friday, will be fitted Monday with abit of luck. Will let you all know how I get on. Thanks fir all your help
Offline Cadders96
« Reply #11 on: August 16, 2017, 03:18:23 pm »
Put some pics of it on here and any modifications required for it to fit to the 3" catback system as I am looking to do this
VW Golf GTI Mk5 3 door
18" Monzas
Tinted Windows
Powervalve WRC Sports Cat-Back Exhaust with Decat Downpie 3" (Ebay Special)
Climair Wind Deflectors
HID Foglights
GFB DV+
Pre-Cat Delete
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 79
« Reply #12 on: August 16, 2017, 03:28:13 pm »
I'm guessing there's probably a reducer on the catback to mate up to the oem downpipe.
So technically after fitting the new dp, it'll now be 3" reduced to 2.5" then back to 3"
Decat will make it loud, should sound good.
Does the catback have a resonator and muffler?
« Last Edit: August 16, 2017, 03:31:39 pm by MIJ_JAGGER »
Offline Dave_d
« Reply #13 on: August 16, 2017, 05:35:59 pm »
I've got no idea! As I say I'm not clued up on exhausts. I'll post some pics of underside of exhaust. Maybe you will be able to tell
Offline Dave_d
« Reply #14 on: August 16, 2017, 05:45:56 pm »
I'd hazard a guess on it being non resonated. I've done a video on a view of the exhaust. Maybe you can tell from the video?
https://youtu.be/cWPiv9Df76k
