Author Topic: Stereo with compatible canbus revision  (Read 2156 times)
Offline Dave_d
« on: August 17, 2017, 09:41:31 pm »
Ive just bought a new stereo off eBay (see picture)
It states that I wil need a new canbus gateway as mine is revision F, found this one  on the internet  that is a Q revision. Is it fairly simple to code the Q revision gateway to my car? I have VCDS at my disposal.
IMG_5387" border="0
IMG_5388" border="0
Dave
Offline Pashka
Re: Stereo with compatible canbus revision
« Reply #1 on: August 18, 2017, 10:20:11 am »
You will need 7n0 gateway to get it connected with the stereo. With this one, it will not drain your battery, but you will not have connection via VCDS with the stereo as it is the new one. Same thing with 315 and 1k0 gateway.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Dave_d
« Reply #2 on: August 18, 2017, 10:38:59 am »
Does the gateway have to be connected to the stereo then for it to function etc? Or will it lose the volume up and down function on the steering wheel? I never use that anyway as out of habit I turn it manually @Pashka
Offline Pashka
« Reply #3 on: August 18, 2017, 10:40:38 am »
You shouldnt be able to use your wheel or see any info on the instrument cluster.
Offline Dave_d
« Reply #4 on: August 18, 2017, 10:56:33 am »
I will lose mpg and distance etc off my multi function wheel? I don't have high line clocks. Think mine are called midline clocks. @Pashka
Offline Dave_d
« Reply #5 on: August 18, 2017, 06:27:35 pm »
@Pashka  what are the implications of not using a 1k0 versus  7n0 gateway? I'm confused.
Offline SI-R32
  • -Receive: 125
« Reply #6 on: August 18, 2017, 07:13:48 pm »
1k0 just superceded by 7n0, if you use any later versions of 1k0 or any version 7n0 its all relatively the same for battery drain purposes
Offline Dave_d
« Reply #7 on: August 19, 2017, 01:12:35 pm »
Sorry I'm really confused here..  :thinking: I will need a 7n0 canbus for the stereo to work with drain? If I go with the 1k0 then it can't be coded with the stereo  so I will lose all of the multifunction steering wheel buttons like mpg etc? @Pashka @SI-R32
Offline Pashka
« Reply #8 on: August 19, 2017, 04:56:19 pm »
1k0 will fix the battery drain issue, just wont connect with your stereo. It means no mfsw control for the stereo, no stereo info on the dash. It has nothing with mpg etc. cheers
Offline SI-R32
  • -Receive: 125
« Reply #9 on: August 20, 2017, 09:34:58 pm »
sorry about confusing you mate, i picked up from post 5 and didn't bother reading your original post, so my bad.
hope you get it all sorted
