Author Topic: Front seat covers  (Read 2384 times)
Offline Dave_d
Front seat covers
« on: August 17, 2017, 10:04:19 pm »
Hi. Does anyone know if the front seat covers are easily removed? My electric lumbar support in my drivers seat is knackered. (Collapsed one side and clicks in all directions)I'd like to see if I can repair it. Any tips? Tricks? Etc
Dave
Offline chigmuss
Re: Front seat covers
« Reply #1 on: August 24, 2017, 11:25:40 pm »
Easy isn't a word I'd associate with cover removal Dave, and definitely not on re-install. The underside of the cover has clips which are not so bad, but the fabric tends to have wires across which embed into the foam and attach with circular sharp ended clips which are clamped together to complete the circle. They are b**chin to get back on. I'd let an upholsterer do it as it can look gash  if you don't get the tension back in the covers.
Offline Dave_d
« Reply #2 on: August 25, 2017, 07:48:27 pm »
Thanks for taking the time to reply to me @chigmuss
I think I will just live with the lumbar being broken then.
Offline doylebros
Offline doylebros
« Reply #4 on: August 25, 2017, 07:59:52 pm »
Not a MKV but this gives you an idea of the type of challenge you would be undertaking its photo heavy so helpful but a MKIV seat is better built than a MKV
http://vwgolfr32.co.uk/fitting-guides/heated-seat-element-guide.htm
Bit further info which is the MKV
http://www.golfmkv.com/forums/showthread.php?t=142600
« Last Edit: August 25, 2017, 08:57:38 pm by doylebros »
