Author Topic: MFD2 ipod connectivity  (Read 7316 times)
Offline jsd
« on: December 27, 2008, 11:49:48 pm »
Hi, i got my golf gt tdi 4 weeks ago and would really like to connect my ipod to the car. I know you can buy a lead for it and have heard you can connect something to the cd changer in the armrest. Whats the best option, i dont want to open the mfd2 unit up at all.
thanks! :xmassmiley:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: MFD2 ipod connectivity
« Reply #1 on: December 28, 2008, 11:39:13 am »
Hi jsd,
Have you got the Highline display on your car??
Offline jsd
« Reply #2 on: December 28, 2008, 04:01:19 pm »
Hi Steve, I'm not sure what that is but is :ashamed: that the on board comp in the dash which gives you turn by turn etc. if so yeah i have?
Offline cmdrfire
    • Commander Fire - my blog
« Reply #3 on: December 28, 2008, 04:59:08 pm »
The 6-cd changer can be replaced with an OEM iPod connection (or MDI I think), but you can't have both 6-cd and ipod AFAIK.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: December 28, 2008, 06:07:49 pm »
Sound like it, if so you either have the option of the VW OEM (in arm rest) iPod dock like cmdrfire has mentioned or IMHO I would go for the Dension kit as this can display the song info on the highline cluster unlike the VW kit which is very limited.  :happy2:
Offline jsd
« Reply #5 on: December 28, 2008, 09:17:15 pm »
ok, so for the most minimal work, do i just unplug the cd changer from the armrest and add a connector to the lead? I'd happily swap my ipod for a cd changer!
Thanks for the Dension kit, its 80 pounds at halfords inc fitting, how hard isit to do yourself Steve?
thanks for the replies
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #6 on: December 28, 2008, 09:42:52 pm »
You will need to connect it directly to the back of the head unit as the connector is different on each end.
Fitting is easy but means pulling a bit of the dash board apart.
TBH if the Halford one is this version - http://www.dension.com/GW100.php and you aren't too keen on pulling the headunit out then it's not a bad deal really.
Offline jsd
« Reply #7 on: December 29, 2008, 07:58:19 pm »
Ok will go down local halfords and let you know, any recommendations on where to get it online Steve?
thanks
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #8 on: December 29, 2008, 08:30:12 pm »
I have used these guys before and found them to be very helpful, http://www.ipodcarkitdirect.co.uk
Just drop them an email to confirm if a do the CAN BUS version that supports the cluster display as there website isn't very clear.  :happy2:
Offline Lean
  • DSG +..
« Reply #9 on: March 02, 2009, 11:06:56 am »
Does the Dension kit play via the radio ie: like a fitted FM transmitter or does it go through the system via the aux or something - Basically I just want to know is the sound 'normal' or 'FM' quality like the transmitters are ( I have one and the sounds poooo!)
matt a
« Reply #10 on: March 02, 2009, 02:12:44 pm »
I'd personally go the oem route and get the Ipod armrest dock, would mean unplugging and removing the 6 disc, and replacing it with the ipod dock.
Ill take a pic of mine, if you want?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: March 02, 2009, 04:15:15 pm »
The dension kit goes in via the CD Changer port so is like an aux in  :happy2:
Like Matt says the VW one is the best phyiscally integrated to the car but is a bit rubbish on the functionality side.
Offline Lean
  • DSG +..
« Reply #12 on: March 03, 2009, 10:49:51 pm »
hmmm I have MFD2 & 6CD changer (all oem) - I want the great quality but like you say vw version is not so hot on the functionality side of things.
What is my best option - considering price as well?
also I'm thinking if I replaced my MFD2 with a new all all in one sat nav/dvd malarky and storage space or ipod input it might not be so much more?  :confused:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #13 on: March 04, 2009, 08:06:13 am »
Do you have the highline cluster?
matt a
« Reply #14 on: March 04, 2009, 09:51:14 am »
Yeah that is a very good point, and I think I over look the poor functionality of the VW ipod dock; you have no control over what you listen to, you can set up 6 playlists, but thats it, no track names either.
