Author Topic: Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication  (Read 22148 times)
Offline northernmunkey1
After getting a VCDS done the following code come up - Fault Found: 01134 - Alarm Horn (H12)   004 - No Signal/Communication.
After having a quick read on the net I hear its a tough little bugger to get.
How much would it cost to replace one on a 2005 GTI mk5 and anywhere in the Birmingham area?
« Last Edit: August 22, 2017, 05:23:59 pm by northernmunkey1 »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication
« Reply #1 on: August 21, 2017, 10:29:17 pm »
£30 brand new off china ebay. I've had them replaced on 2 of my golfs. You its located behind driver wing. You will need to take the wheel arch lining out. The alarm is held in a metal case which is riveted onto the chassis. Drill those rivets out, remove metal case, replace alarm and pop some new rivets in and the rest is reversal of removal
Sent from my SM-G955F using Tapatalk
« Reply #2 on: August 22, 2017, 08:16:57 pm »
Sounds simple but Knowing me it will take for ever and I don't have a rivet gun.  There are so many versions not sure which will fit my car?
Offline Christiank
  • -Receive: 39
« Reply #3 on: September 03, 2017, 01:21:06 pm »
Well mine had the same error.. And my rivits was a pain in the ass to drill out. Got everything removed, but didn't had the time to bolt it new the stuff back in place hehe.
« Reply #4 on: September 10, 2017, 12:44:57 am »
Yes took it to a breakers today and it took ages to get off.  He then plugged it into some portable device like a massive tablet and did a system reboot check which turned on the wipers, opened the rear boot and petrol cap and the alarm beeped.  He then mentioned that the battery inside the  siren needed charging so it could work properly and I was told to run it for a week.
Does this make sense and is the alarm suppose to beep when you turn it on and off?
Offline mvb12
  • -Receive: 64
« Reply #5 on: September 14, 2017, 12:11:51 pm »
PM'd buddy
if you mean turn on and off as in lock and unlock then yes if this has been coded this way.  :happy2:
« Reply #6 on: September 14, 2017, 08:57:28 pm »
PM'd buddy
Yes that's what I meant buddy.  Going back to garage this weekend hope it can be sorted
