Author Topic: Cluster upgrade  (Read 1037 times)
willni
Cluster upgrade
« on: August 27, 2017, 08:18:40 am »
Got a set of 972 highline clusters, and just want to make sure all I should need is a VAG tacho to get the SKC code (as I can't find my spare key with the tags on it) and then I'd need the VAG Can K commander to actually do the coding/swap.
Or even better any forum members able to do it in Northern Ireland?
Also anyone had any experience using the ebay tacho and can commanders like the ones below?
http://www.ebay.co.uk/itm/VAG-K-CAN-Commander-1-4-OBD-OBD2-II-USB-Diagnostic-Cable-for-Skoda-Seat-Audi-VW-/272595272994?hash=item3f77f1c522:g:UB4AAOSwTM5YzT7V
http://www.ebay.co.uk/itm/VAG-TACHO-3-01-Opel-Immo-Reader-AirBag-EEPROM-KEY-PIN/322669269560?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D869499bc6659493cb74d242a8e83c469%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D272595272994&_trksid=p2481888.c100675.m4236&_trkparms=pageci%253Ab61d232a-8af6-11e7-ae50-74dbd180cfdd%257Cparentrq%253A22866a1215e0a9c9a60095f2fffc6767%257Ciid%253A1
« Last Edit: August 27, 2017, 09:15:16 am by willni »
willni
Re: Cluster upgrade
« Reply #1 on: August 27, 2017, 09:11:08 am »
Update - Found my spare key with the tags, doesn't seem to be a SKC code on it unfortunately
