Author Topic: Aux Retro Fit  (Read 1822 times)
Offline zenicman9
Aux Retro Fit
« on: August 30, 2017, 01:43:36 am »
Hi All,
I have the standard MK5 Golf Stereo in my car and looking at the best-recommended solution to have either an AUX cable or Bluetooth to allow me to play songs direct from an Android phone.
Has anyone ever done this and can provide a good recommendation?
Offline eric87
Re: Aux Retro Fit
« Reply #1 on: August 30, 2017, 03:56:40 am »
I'm in the same boat but will more than likely get a rcd510. The screen on my current one is buggered and can barely read the display.
Offline Dave_d
Re: Aux Retro Fit
« Reply #2 on: August 30, 2017, 08:12:19 am »
If you have a rcd300 you can buy a connects2 aux adaptor that mimics your cd changer. I conveniently have one for sale on eBay at the minute. It's at£20 at the minute
https://www.ebay.co.uk/itm/272821468025
Offline The Red Warrior
Re: Aux Retro Fit
« Reply #3 on: August 30, 2017, 02:03:35 pm »
Hi All,
I've got a genuine 9w2 Bluetooth kit with the full wiring loom. This will allow you to stream music and use steering wheel controls to answer and hang up calls if you have them.
$50 plus postage. I'm in Auckland.
Offline thenorthster
Re: Aux Retro Fit
« Reply #4 on: August 31, 2017, 08:11:47 pm »
I fitted a Connects2 from eBay to my RCD300 last weekend. Taking the dashboard apart is a bit of a faff and you'll need a torx screwdriver, but worth it - all works nicely, good clear sound and much cheaper than replacing the radio (not to mention avoiding any of the can bus gateway upgrade / battery drain issues).
2005 Mk5, 3 door, tornado red (naturally)
Offline zenicman9
Re: Aux Retro Fit
« Reply #5 on: August 31, 2017, 10:05:09 pm »
Did you mount it into the Glove Box or the center console?
Offline Rado16v
Re: Aux Retro Fit
« Reply #6 on: September 01, 2017, 06:41:44 pm »
Has anyone fitted one of these jobbies to the standard stereo?
Link to it
https://m.aliexpress.com/amp/item/32827454138.html
Offline Dave_d
Re: Aux Retro Fit
« Reply #7 on: September 02, 2017, 07:44:01 am »
Hi rado, it won't work if you have a rcd300, I tried it on my rcd300, it's not compatible with the generation of radio, you will need a connects2 kit for aux On a  rcd300.
Re: Aux Retro Fit
« Reply #8 on: September 02, 2017, 01:36:09 pm »
I used a longer 3.5mm to twin lead, dropped the Connects2 box down the back of the radio (lots of room down there) and trailed the lead out of the top of the dashboard above the vents, where it runs down the side and to my phone in the glove box. Looks a bit rubbish, but I was concerned I'd hit an airbag wire finding my way into the Glove Box through the side, and couldn't work out how to emerge down by the ashtray without drilling or snapping plastic.
