Author Topic: Which canbus for upgrade?  (Read 12849 times)
Offline Gmac
  • -Given: 30
« on: September 01, 2017, 09:17:33 am »
Morning folks...
Just want to clarify that ANY canbus module after 'L' will avoid battery drain issues?
My car is '07 plate, march. And it has version 'H' atm. I've bought a rcd310 dab.
Looking at a 7N0 907 530 AR and also 1K0 907 530 AD
I have full vcds to code it
Tia
Offline shoaybmakda
  • -Receive: 54
Re: Which canbus for upgrade?
« Reply #1 on: September 01, 2017, 09:36:01 am »
I believe revision L onward should be ok
Offline Gmac
  • -Given: 30
« Reply #2 on: September 01, 2017, 10:37:05 am »
Thanks bud,
Yeh that what I was thinking so either of the modules I've listed above will be fine I reckon.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #3 on: September 05, 2017, 03:54:52 am »
Any 7N0 will do
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Gmac
  • -Given: 30
« Reply #4 on: September 06, 2017, 06:48:02 am »
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #5 on: October 12, 2017, 02:44:14 am »
I recently changed my gateway from a rev L to 7N0 907 530 AM, the main reason was to support extra functions in my rocco clocks that i wanted ie i now have rest mode enabled & i will be adding TMPS High version so it will show the pressures in the display plus i got the gateway for silly cheap £20 & i sold my old rev L to a friend for the same price as i paid for the new one.
« Last Edit: October 15, 2017, 11:42:06 pm by mrxbox360 »
Offline eric87
« Reply #6 on: October 19, 2017, 08:05:55 am »
Using a 7N0 907 530 AH here no problems coding.
Offline Christiank
  • -Receive: 39
« Reply #7 on: October 21, 2017, 10:07:18 pm »
7N0 will allow you to do more retrofits since it's from a newer car.
I'm using 7N0 "AS" .. This gives you EXT.can, 5F and much much more :)
Offline mrxbox360
« Reply #8 on: March 07, 2018, 08:56:23 pm »
Hi what is 5F and what else does it support.
Offline Pashka
« Reply #9 on: March 11, 2018, 06:22:34 pm »
5F is MIB headunit from G7 etc. 7n0 supports all retrofits, for example lane assist/high beam assist.Also, has fatigue detection option. If somebody need one I can do precoded ones for your car.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Webup
« Reply #10 on: April 25, 2019, 08:38:10 am »
How much are they please for mk5 GTIs?
