Author Topic: DSG - Jerking in 1st and Reverse - Garage Recommendation  (Read 15305 times)
Offline Tuffy90
Re: DSG - Jerking in 1st and Reverse - Garage Recommendation
« Reply #15 on: September 30, 2017, 02:33:39 pm »
The other place recommended on here for DSG repairs is a place in Bristol, not exactly on the doorstep but that and the Nottingham one have had high praise.
Think I've saved the link so will have a look.
Here you go.
http://www.mk5golfgti.co.uk/forum/index.php/topic,107090.0.html
Cheers mate. Definitely closer than Slaters but good to have a reputable company to go for. Must looking them up, still haven’t got this repaired.
Offline noj66
« Reply #16 on: October 19, 2017, 05:17:20 pm »
Hi,I'd be interested in how you get on with this.I bought a 08 Mk5 GTI DSG in April that displays the same symptoms.To be honest it's driveable and 90% of the time doesn't bother me but when it's hot in traffic or reversing it's really jerky.I have owned more than a dozen DSG Golfs and this is the first that's faulty.I suppose my luck had to run out sooner or later.I'm reluctant to spend much on it as the car was only 7k. I think a secondhand box from a breakers would be my best option.
Offline mk1mad
« Reply #17 on: October 19, 2017, 06:06:59 pm »
Mine is the same in three years it's not got any worse. Bit risky buying a secondhand box could end up with the same  problem as it's fairly  common on mk5's.
I will use the place in Bristol they have had very good feedback.
Edition 30
Golf Mk1 5vT
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #18 on: October 19, 2017, 10:26:36 pm »
Ain't there companies that could repair this instead.
Would this not be cheaper.
£700-800 quid
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #19 on: October 19, 2017, 10:31:37 pm »
Where you based ?
Online Andy
« Reply #20 on: October 20, 2017, 11:11:59 am »
mine started jerking into 1st gear and it turned out to be seized caliper
Offline phantom1004
« Reply #21 on: November 08, 2017, 06:08:39 pm »
Before jumping and spending xxx money on a mech pack or such try a dsg reset, mine had simular problems with the addition to 3rd, did a TB and DSG reset and i think due to the fault of my own it was worse (usb power savings on a laptop) but after about a week it got better, last week i replaced my TB and thought for the hell of it id do another dsg reset and it was perfect after the run in setup, if you have vagcom or know someone that does give it a go, all of my symptoms were pointing to mech but as stated, a reset and recalabration drive and it drives like its never had a problem
Offline Tuffy90
« Reply #22 on: November 19, 2017, 05:11:36 pm »
Had a reset done twice but didn’t work for me unfortunately!
Where you based ?
Based in South East London.
That would be the dream!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #23 on: November 19, 2017, 08:00:27 pm »
My rear seized caliper kept on bringing on the tpms on but front may differ!!! If you are sure it's not the gearbox mount like mine was when I had this issue nearly three years ago then it may sadly be the mech unit!.
Offline Tuffy90
« Reply #24 on: November 19, 2017, 08:24:15 pm »
Is there an easy way to diagnose this?
Online Andy
« Reply #25 on: November 20, 2017, 01:32:00 am »
jack the car up or on a 2 post ramp and the spin the wheels by hand and the should.spin very easily
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #26 on: November 20, 2017, 08:59:30 pm »
If you have an assistant put your car in drive with handbrake on and rock the car forward in gear whilst you look at the passenger side wheel for abnormal movement!. Anther way is to grip ahold of the engine gearbox side and try move it back and forth and if this moves reasonably easy replace gearbox mount. I did have a video on my build thread but due to photobucket being greedy they've blocked all pictures and videos.
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,96115.msg955433.html#new
« Reply #27 on: April 02, 2018, 08:46:28 pm »
@Tuffy90 - Did you solve it? I have the same issues, with no errors logged, I’ve been told to change the clutch pack.
Offline Tuffy90
« Reply #28 on: April 02, 2018, 09:00:56 pm »
Hi mate, no never got around to it yet! Was going to visit the garage in Bristol for them to have look before doing anything. Let me know if you get around it!
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #29 on: April 03, 2018, 07:51:51 am »
I'll try replacing the clutch pack first, since my gearbox wasn't new and I don't know how was it used.
