Author Topic: MK5 GTI track Slag  (Read 15575 times)
Offline L33
Re: MK5 GTI track Slag
« Reply #30 on: October 12, 2017, 03:41:24 am »
Hahaha my daily doubles up as a track hack. Give me one of your mk2’s.
« Reply #31 on: October 13, 2017, 03:28:53 pm »
Passat/S3 hubs
The damper hasn't hit full insertion into the hub.  Did you clean out all the corrosion first?  The alloy ones crust up really badly in the damper hole.
Also looks like you've used the tie rod nuts off the steel wishbones?   You need to fit Passat ones asap or the steel inserts will pull through.
Offline vag
« Reply #32 on: October 14, 2017, 07:46:54 am »
Thanks for the concern, they are BC racing coilovers and have a lip on top which is butted against the hub, Don't worry all seated correctly. The nuts a Passat specific, you can see the big flanged nut  :happy2:
« Last Edit: October 14, 2017, 07:49:29 am by vag »
Offline vag
« Reply #33 on: October 18, 2017, 09:16:01 pm »
Changed the rear setup with camber arms so i can get some proper camber on the back now
Added some aero from A3
Front pads lasted 4 sessions of Brands, they did not fade once. Really did take a beating though!
Offline Stig_gti
« Reply #34 on: October 18, 2017, 10:52:04 pm »
What break setup you running
Offline vag
« Reply #35 on: October 19, 2017, 02:59:01 pm »
Standard size bremo drilled discs with ds2500 pads
« Reply #36 on: October 26, 2017, 04:48:32 pm »
Good stuff  :happy2:
Liking the under plastics from the A3, nice touch!
Offline Paradox1
  • -Given: 41
« Reply #37 on: October 27, 2017, 10:53:52 am »
You got a PN for the Aero kit?
Offline Simon_2.0t
« Reply #38 on: October 27, 2017, 01:55:01 pm »
Great thread mate. Recognize some of the units in the pics, you local to Crawley?
Si
Offline vag
« Reply #39 on: October 28, 2017, 04:54:13 pm »
Si
 :scared1:
Poundhill  :love:
Offline vag
« Reply #40 on: January 15, 2018, 10:02:34 pm »
Thought i'd update the thread with pictures from the last track day
Managed to do 184 laps of the indy circuit, the car did not miss a beat, I was shattered by the end of the day.
I'm looking for 17s now as i reckon the car will handle better and i want to get her lower.
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #41 on: January 16, 2018, 06:11:27 am »
Nice pictures! For sure running on 17" would be better for traction and tyre costs, but at some point you will need bigger brakes and you cannot fit a good BBK under 17". I'm tracking mine with a 6pot AP Racing kit and custom brake ducts, I still have some brake cooling issues on full slicks.
