Author Topic: Puddle lights, folding mirror retrofit questions  (Read 9258 times)
Offline Christiank
  • -Receive: 39
Re: Puddle lights, folding mirror retrofit questions
« Reply #15 on: October 27, 2017, 07:23:35 pm »
Yes 1 wire have to be pulled from the comfort module there's located behind the glovebox. It's only needed to pull the signal / +12v wire to the doors from the comfort module since you can take earth from the door somewhere :)
You'll have to locate connector F on the module and then left door (LHD) is pin 5 and right side is pin 12.
However I'm not sure if these should be switched over when you have a RHD car?  :surprised: :confused:
« Last Edit: October 27, 2017, 07:26:49 pm by Christiank »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #16 on: October 27, 2017, 09:52:58 pm »
Boom there blows the ecu  :scared:
Glad you've sorted yours out though  :grin:
