Evening all,
First post on here but I've been frequenting on here recently and decided to finally sign up. I used to be around on the UK-MKIVS forum when I used to have my old MK4 a few years ago but it's not as active as it used to be.
I picked up an 07 GT TDI back at the start of August and overall been very happy with the car. I've done a few minor things to it just to keep it original as possible and just about there with it. However since owning it, I've always noticed that the rear of the car tends to sit lower than the front just slightly. As far as I know - it's still on OEM suspension all round, however it did have the front springs replaced back in 2013 with OEM GT spec Sachs according to a past invoice and I'm fairly adamant that both rear springs were replaced back in 2015 as a past MOT indicated a broken rear spring.
However I have no record of what rear springs they were replaced with, though they look identical to the OEM pair that Sachs make. The ride height on the front looks spot on for a GT TDI when comparing others out there but the rear just sits a good 1 - 1.5CM too low than how it should. Besides the fact that it may have the wrong rear springs fitted, is there anything else on the rear suspension that could hinder overall height appearance? As far as I can tell, the car is still on the factory shocks as well (car currently on 108K). I'm half debating going for 20-30mm lowering springs anyway but I'm holding back for now just incase another suspension component could be at fault. The overall feel & ride while driving still feels as it should (no knocks, bangs etc.).
I'll get a photo up of the car to give a better idea tomorrow as well.
Many thanks - Liam.
