My lowline display (half height digital part between the speedo and rpm counter) has just died.
Driving along I look down and can see only a thin horizontal line instead or the usual odometer/time etc reading. 2 mins later the display is totally blank. Speedo, rpm, temp and fuel clocks still work fine and warning lights appear when cycling the ignition. Just the screen appears to be dead.
Anyone had similar and any suggestions? I'll plug into VCDS when home in a few hours and see if anything is thrown up...
