November 15, 2024, 11:36:25 am
All Things Mk5
Mk5 General Area
Mk5 gti engine issue
Topic: Mk5 gti engine issue (Read 1266 times)
SAT_GTI
Can't Read PM's Yet!
-Given: 1
-Receive: 0
September 18, 2017, 12:15:39 pm »
Hi my mk5 gti broke down on me last week.. heard a loud noise come from the engine so i turned the engine off and car wouldnt start at all after that.. so got a new starter motor now the car starts but i have a horrible noise coming from engine. Need to find out what is the possible cause if someone can help.. ive put a video up so everyone can hear
mycarnowork
Taking part
-Given: 0
-Receive: 2
Re: Mk5 gti engine issue
Reply #1 on:
September 18, 2017, 02:38:44 pm »
Why did you replace the starter motor? I'm assuming you thought it was not working but how did you diagnose it?
Can't see how a failed starter motor would make your car breakdown.
SAT_GTI
-Given: 1
-Receive: 0
Reply #2 on:
September 18, 2017, 05:19:58 pm »
Once the engine had started making noise I turned the ignition off straight away.. after that it wouldnt tick over at all.. vw mechanic said start with the cheapest option by changing starter motor.. so car is starting but the noise it whats issue now
mycarnowork
Taking part
-Given: 0
-Receive: 2
Reply #3 on:
September 18, 2017, 10:15:33 pm »
Startor motor might be unrated. I'd be taking the chain cover off and check the tentioner. If that goes you'll have the same problem I just had with the chain snapping(big headache). Also high pressure fuel pump has a cam follower which is like a bucket and they can where through.
I'm no mechanic but I would check them.
SAT_GTI
-Given: 1
-Receive: 0
Reply #4 on:
September 18, 2017, 10:55:46 pm »
Cam chain, adjusters, pulleys were all changed last year. So was cam follower.. i think its the hydraulic lifters causing this problem
All Things Mk5
Mk5 General Area
