Author Topic: Mk5 GTI rattle and boost issues  (Read 2138 times)
Offline tyc00n2
« on: September 23, 2017, 03:48:07 pm »
Hi all!
Had my tfsi gti since March, hasn't been the smoothest ownership but I'm sticking with it!
So my lemon has recently developed a rattle at idle if I rev to about 2500 and let off the throttle, sounds similar to the actuator issues on tsi engines. Is this a well documented issue on TFSI engine also? The car also doesn't produce boost at start up, sounds like all the boost is being vented until about 1 minute of driving. I'm leaning towards maybe a bad DV as I haven't changed this yet. The car has a brand new PCV.
Any thoughts guys?
Stephen
Offline NickGTi
Re: Mk5 GTI rattle and boost issues
« Reply #1 on: October 27, 2017, 01:48:35 pm »
The rattle you mention sounds like a similar fault I had when I bought mine.
It turned out the actuator arm needed adjusting as it had become loose.
The way to do it is on this thread:
http://forums.vwvortex.com/showthread.php?6988116-2008-FSI-GTI-Rattle-on-Engine-Deceleration#/topics/6988116?page=5
Easy to do once under the car, a few turns of the adjuster and re tightening the nut, job done!
