Author Topic: Golf mk5 gti wont start  (Read 2436 times)
Offline Shanedixon
« on: September 24, 2017, 09:06:10 pm »
Hi guys im anewbie here just purchased a mk5 golf gti , basically what happend it came up with a oil pressure low warning stop! The engine just conked out and now it wont start took it to a garage and they said it needs a new engine i asked why and thats what they assume , i dont want to replace engine if its not needed can any1 help or give me some ideas ? The cambelt hasnt snapped i looked through the plastic cover , possibly slipped who knows ?
Offline Golfman16
Re: Golf mk5 gti wont start
« Reply #1 on: September 25, 2017, 12:20:55 am »
Id say the oil pump drive has failed buddy common prob on mk5 Axx engines drive cog collapses thus no oil pressure , can be ok if sorted on time ie chain rattle looks as if yours hasnt , new engine is lookin like the only option fella  :sad1: :sad1:
Offline Shanedixon
« Reply #2 on: September 25, 2017, 12:48:34 am »
Damn i had a feeling it was going to be this is there any way to know 100% ?
Also any recomendations where to get a used emgine from or can these be rebuilt ?
Offline Golfman16
« Reply #3 on: September 25, 2017, 10:04:08 pm »
Drop the sump off see  whats what ,engine should be that difficult to pick up plenty of mk5s & audis (same engine Bwa ) chopped up now.
Offline Shanedixon
« Reply #4 on: September 26, 2017, 06:26:54 am »
Yer i boughy an engine last night for £1100 on ebay with turbo etc and mechanics going to fit it for £150 once it arrives might service it before the engine goes in
Offline Golfman16
« Reply #5 on: September 26, 2017, 11:00:49 pm »
Do
All the servicing on the floor
Mate belt water pump etc plus I'd be doing the cam chain & tensioner while your there . Do no harm to drop the sump check the oil pump drive & clean the lift pipe ..
Hope it works out for you mate 👍👍
Offline Shanedixon
« Reply #6 on: September 28, 2017, 02:22:47 pm »
Yer im going to it should be here tomoz just done a bit more digging on the golf the oil level is really high i done a vagcom scan also and heres what it come bk with
P000a-008Camshaft position (bank1 intake) slow respsonse
P0333-001Knock sensor 2 signal too high
P0342-002Camshaft position sensor g56 signal too low
P1063-002Fuel pressure regulation control range not reached
Can any1 confirm this is buggered before i take the engine out
