Author Topic: Golf mk5 gti oil level light won’t go off  (Read 16693 times)
Joe1991
« on: October 08, 2017, 09:23:10 pm »
Topped my mk5 gti golfs oil up as it was low and the oil light won’t go off? How do you do this?
Offline andy7ven
  • -Receive: 30
Re: Golf mk5 gti oil level light won’t go off
« Reply #1 on: October 11, 2017, 07:22:09 pm »
When you get the oil low warning, opening and closing the bonnet should take the light off, so I would say faulty bonnet catch!!!
Offline Wijesunde
« Reply #2 on: October 11, 2017, 09:21:57 pm »
you have to drive atleast 80km or so! and it will go away
Offline Llew
  • -Given: 45
« Reply #3 on: October 12, 2017, 11:28:33 am »
mines take a while to off if the light comes on and i top it up roughly about 80km as previously posted
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #4 on: October 12, 2017, 07:47:43 pm »
While the car is idling, try your front window wipers, if they don't work, it points towards a faulty bonnet catch switch.
The wipers will work when driving through.
As you look at the bonnet catch, slightly off to the left, the bonnet catch switch connects to the car loom. Try disconnecting it, this will make the car think the bonnet is closed. Cycle the ignition, start the car, oil light should go out and wipers will work.
If it is the switch, check for breaks in the wire, try cleaning up the Connections and the bonnet catch.
Jas
VCDS (Preston, Lancashire)
Offline tyc00n2
« Reply #5 on: October 13, 2017, 07:27:40 pm »
Can confirm as others have posted if the oil light comes on, top it up and after maybe 40 or so miles it goes off. The ding everytime I turn the car on makes my jump though aha
Offline bigrich690
« Reply #6 on: October 14, 2017, 11:21:02 am »
Had the same problem with mine, tried all sorts and in the end it was the bonnet catch, one wire was broken so it wasn't seeing that i'd opened the bonnet, you'll know as the light on the dash showing your bonnet open won't be lit up, just cut the other wire and twist them together, turn over the engine for a few seconds and your oil light will go out, then untwist the wires and make them safe or cut them short and do without the sensor, it worked for me
« Last Edit: October 14, 2017, 11:24:05 am by bigrich690 »
Red 3 Door GTI, Lowered, 18" 3SDMs, Remap, Heated leather, Xenons.....
