Author Topic: Cruise Control Stalk Switch  (Read 1050 times)
Offline jaylufc17
  • -Given: 48
« on: October 11, 2017, 02:41:35 pm »
anyone had there cruise control stalk switch play up?
only had my stalk had my stalk installed last year and its stayed on the on switch ever since probably change under 5 times. According to VAGCOM everything is active and working :thinking:
fault as below
1 Fault Found:
00895 - Cruise Control Switch (E45)
            014 - Defective
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Cruise Control Stalk Switch
« Reply #1 on: October 11, 2017, 03:03:18 pm »
Never had an issue when mine was retrofit and it's been 3 years.
Mine has always been in off position unless in use.
Was it an OEM or aftermarket stalk?
Have you tried the basic flicking it on and off about 20 times and jiggling it?
If this fails and you can't reset code then it could mean you need a new stalk. Since the control module is there already then you could get an aliexpress special for maybe €20
Offline shoaybmakda
  • -Receive: 54
« Reply #2 on: October 11, 2017, 09:25:22 pm »
Just sold a rev g stalk brand new on eBay for £10!
