Author Topic: Remote Locking no longer working  (Read 1172 times)
scott2326
« on: October 11, 2017, 11:19:57 pm »
Good evening all. I hope some one can help
Me with my current issue!
So the central locking no longer works with the key remote.
The car will lock with the key and also from the switch on the inside. But if locked with the key the alarm sometimes sounds after a few minutes.
I only have the one key, the red light lights up with the button is pressed by I've fitted a new battery just incase.
Taken into garage a key have been checked, it's sending a signal and is still programmed. Try to reprogram with vcs and also with a new key fob but the car doesn't seem to be receiving the signal.
Is the BCM where the signal is received? If I get another does it need to be programmed or is it a straight swap?
All help much appreciated, staring to pull my hair out now!
Thanks!
CHAZHALK1
Re: Remote Locking no longer working
« Reply #1 on: November 02, 2017, 10:27:25 am »
Hi I'm having similar problem did I resolve this
