Author Topic: Wheel Bolts  (Read 1235 times)
Offline delob
Wheel Bolts
« on: October 13, 2017, 06:17:36 pm »
Might be an obvious answer to this but I am at a loss. Have just bought some Eibach spacers for my GTI and need to order some new lugs. I know that I need 14x1.5 with a 17 head. I am going for 40mm thread with radius seating but have 2 options of r12/r14. Anyone help with the last bit?
Graphite Blue MK5 GTI
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Wheel Bolts
« Reply #1 on: October 13, 2017, 06:31:49 pm »
If wheels are oem...they should be r12.
If wheels are 5x112 aftermarket...you may want to find a 12mm and 14mm radius and check the wheel's ball seat radius yourself.
« Last Edit: October 13, 2017, 06:35:17 pm by ROH ECHT »
Offline delob
Re: Wheel Bolts
« Reply #2 on: October 13, 2017, 07:18:55 pm »
Thanks for the response. They are oem 18” Monza 2. I will take one of the originals off and have a look. What does the r12/14 refer to?
Offline chigmuss
Re: Wheel Bolts
« Reply #3 on: October 13, 2017, 08:49:15 pm »
Radius 12 or 14mm maybe?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
Re: Wheel Bolts
« Reply #4 on: October 13, 2017, 11:18:41 pm »
It's the radius of the ball-seat...https://www.google.com/search?q=r12+and+r14+wheel+bolt+drawing&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi0kPm30O7WAhVEjVQKHSfNAxgQ_AUICygC&biw=1333&bih=606#imgrc=QHA_CtN4LHSBdM:
Correct radius fitment is like needing the same angle if these were conical bolts. Although I believe all conical use the same angle.
« Last Edit: October 13, 2017, 11:21:45 pm by ROH ECHT »
