Author Topic: Super pro adjustable ball joints  (Read 8780 times)
Offline colesey
  • -Receive: 89
Re: Super pro adjustable ball joints
« Reply #15 on: October 22, 2017, 05:53:00 am »
Maybe try the Powerflex adjustable camber front bushes instead of bjs as they give upto 1/2degree more without these brake clearance issues.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #16 on: October 22, 2017, 04:16:37 pm »
I am using super pro ALK mate, I'm looking for clearance for the bj's.
« Reply #17 on: October 23, 2017, 12:26:03 pm »
I’m not sure there is a definitive answer to this question. Obviously the more camber, the more inner edge wear however whether this is premature will also depend on your mileage, how hard you corner, tyre pressures and also your expectations on what wear is acceptable.
I was recommended to aim for 2-2.25 deg but to expect tramlining and uneven tyre wear, however when the bjs were fitted we could only achieve 1.5 equally on each side. Haven’t done sufficient mileage since then to form a view on how the tyres are wearing but would say that it drives nicely on these settings. Fwiw have also used a small amount of toe out both front and rear.
Im trying to find a way to keep them ball joints as far away from the discs as possible as the brake set up I tried once fouled the disc and Ball joint so thinking the super pro adjustables will solve this issue.
IMG 2946" border="0
SP BJs won't solve that I'm afraid.
what would you recommend or think will solve this if anything ? Cheers
Grinding the ball joint is the only fix for that.......or use a brake disc with more offset.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=lsoirn0pc9e73epf6hnlb3c8ih&/topic,19740.0.html
« Reply #18 on: October 23, 2017, 01:03:35 pm »
SP BJ will actually make that situation worse as they are slightly wider/bigger
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #19 on: October 23, 2017, 02:12:50 pm »
I've had that experience and no safe griding of the SuperPro ball joints was enough to solve it. Even the S3/Passat ball joints rub when fitting new discs. I use discs with 350 mm for MB ML450 and I also have alloy arms from the S3/Passat.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #20 on: October 23, 2017, 08:17:36 pm »
i would have thought they'd help as they're adjustable but no expert here
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: October 23, 2017, 08:21:10 pm »
very tricky one here as buying all sorts of different parts and still having the problem wouldn't help matters anymore  :signLOL:
« Reply #22 on: October 23, 2017, 08:29:11 pm »
Sadly not.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #23 on: October 23, 2017, 09:43:07 pm »
Sadly not.
Never mind cheers   :smiley:
« Reply #24 on: October 24, 2017, 09:19:36 am »
The adjustable part of the SP BJs is via the 3 mounting nuts to move the whole hub assembly further out for more camber.  The ball and pin part of the BJ and the disc are fixed into position and cannot be moved away from each other.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #25 on: October 24, 2017, 07:05:43 pm »
when the adjustment is made it automatically pulls the ball away from the disc is what I'm thinking tbh
« Reply #26 on: October 24, 2017, 08:27:11 pm »
No it doesn’t.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #27 on: October 24, 2017, 08:28:55 pm »
It doesn't work that way. The only thing that the adjustment allows is to alter the camber just a bit by extending the hubs further from the centre of the car. The hub is fixed to the ball joint which is much bigger, so it's also closer to the splash shield and brake disc.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #28 on: October 24, 2017, 09:45:14 pm »
No it doesn’t.
oh bugger  :doh:
Must be some way of fitting the Revo and get clearance of the bj's  :thinking:
« Reply #29 on: October 24, 2017, 11:36:04 pm »
Yeah there is... fit different hubs and wishbones.
I thought youd sold that kit anyway?
