Author Topic: Rubbing Issues  (Read 1240 times)
Offline delob
Rubbing Issues
« on: October 28, 2017, 09:10:52 pm »
Bit of advice needed. I recently lowered my Gti and am now getting a rubbing noise from the front driver side. I found a bit of loose wheel arch liner and fixed it up but the issue persists. Only on the driver side front. Happens on speed humps and when turning left at higher speeds. 20mm drop with 10mm spacers. Is this normal?
Graphite Blue MK5 GTI
Offline The Red Warrior
Re: Rubbing Issues
« Reply #1 on: October 29, 2017, 08:58:20 am »
Each set up is different so hard to say. Depends on tyre, wheels, offsets etc.
have you done the 'fender screw mod'?
This may be enough to stop your rubbing. Just search for that and you'll see what I mean.
Offline delob
Re: Rubbing Issues
« Reply #2 on: October 30, 2017, 05:50:37 pm »
Did this today. Seems to have worked a treat. The difference a few mm can make is crazy. Thanks for the tip
Re: Rubbing Issues
« Reply #3 on: October 31, 2017, 07:34:09 am »
Glad to hear it.  :happy2:
