Author Topic: Suspension  (Read 4084 times)
Offline Stig_gti
Suspension
« on: October 29, 2017, 11:41:39 am »
When sitting the shock back into the hub does it drop to a certain point before you tighten it up. Like will only drop so far, or do you put the shock flush to the bottom of the hub and then tighten it.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Suspension
« Reply #1 on: October 29, 2017, 05:48:43 pm »
The fronts are what you are questioning, yes? Then yes, you spread the lower strut mount on the knucle (for removal as well as for re-installment) and slide the strut all the way down after you've secured the upper strut mount at the top. There's a lower tab on the bottom of the strut tube with a hole(or hook-type tab) in it, you'll notice when you remove the struts, that goes into the knuckle slot and aligns to the lower strut bolt. I believe there is a stop that's cast into the knuckle at the lower end of its strut cylinder...you'll feel the strut stop as it hits that stop.
I assume you have a spreader tool such as this; http://www.urotuning.com/Strut-Spreader-Tool-VW-Audi-p/MN3424.htm?gclid=CjwKCAjw-NXPBRB4EiwAVNRLKgT5XP0fCQLLFyOvUP5tE1pUVKOUKrcNUOuqPDgUQE890j54U-Q68xoCdUgQAvD_BwE
...you can use a chisel as well.
« Last Edit: October 29, 2017, 05:57:40 pm by ROH ECHT »
Offline Octoparrot
  • -Receive: 102
Re: Suspension
« Reply #2 on: October 29, 2017, 05:53:44 pm »
There's a lip at the bottom of the hole that the strut should stop against before inserting the bolt and tightening it back up. The lip prevents you sliding the strut down too far, if you spread the hub apart far enough it should be quite easy to slide the strut in and down to its stop.
Offline Stig_gti
Re: Suspension
« Reply #3 on: October 29, 2017, 05:56:19 pm »
Perfect guys thanks that what I was thinking. One last thing if a spring was installed upside down would it affect the height. E.g higher lower
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
Re: Suspension
« Reply #4 on: October 29, 2017, 06:02:05 pm »
Don't believe you can install them upside down as the coil's diameters may differ from top to bottom. I think the upper spring perch is larger diameter, as it is the same diameter of the upper strut bearing...and the lower perch is more the diameter of the shock tube. I could be incorrect...and it doesn't matter one way or the other. Ride height would only be affected if the spring's coils sat differently on the lower perch when upside down.
« Last Edit: October 29, 2017, 07:08:47 pm by ROH ECHT »
Offline Stig_gti
Re: Suspension
« Reply #5 on: October 29, 2017, 10:31:56 pm »
Thank you @ROH ECHT.
Are springs any different between mk6 gti and mk5 gti also do dcc springs differ.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
Re: Suspension
« Reply #6 on: October 30, 2017, 04:17:43 pm »
Without having first-hand experience...I think you should look at some Golf R Forums here. I've read the VWR springs are made to run with DCC and you'd want to stay away from progressive/variable rate springs. Springs for a mk6 GTI should fit the mk5...mk7 to mk5, no.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Suspension
« Reply #7 on: October 31, 2017, 02:38:27 pm »
How about the H&R suspension kit?
Offline Stig_gti
Re: Suspension
« Reply #8 on: October 31, 2017, 04:36:48 pm »
I was on h&r springs to low for me in London.
Changed to kw springs 20/20 raised the back hardly raised the front at all.
So now I’m thinking of going back to standard springs..
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Suspension
« Reply #9 on: October 31, 2017, 07:46:14 pm »
ah footballs  :doh:
Offline Stig_gti
Re: Suspension
« Reply #10 on: October 31, 2017, 07:56:06 pm »
Pain in the arse 2 sets of springs including fitting and tracking. Now might be going back to standard.  :thinking:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Suspension
« Reply #11 on: October 31, 2017, 09:21:03 pm »
I'm in the heart of London so going to expect the same issues as the humps here are super huge  :doh: having said that did you replace the shocks as my TT was 40mm dropped with a votex front over bumper spoiler and a LCR splitter and it did catch but was liveable  :smiley:
Offline Stig_gti
Re: Suspension
« Reply #12 on: October 31, 2017, 09:47:43 pm »
No didn’t replace my shocks still on originals. I have dcc suspension and want to keep it, new shocks from dealer £1000
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Suspension
« Reply #13 on: October 31, 2017, 10:00:10 pm »
I have the H&R comfort suspension kit and thinking because my oem are most likely shot these will be fine and I won't scrape as much as they're not battered or old!!!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Suspension
« Reply #14 on: October 31, 2017, 10:06:50 pm »
IMG 5921" border="0
