Author Topic: How is the cabine and tilt sensor work?  (Read 818 times)
Offline Christiank
  • -Receive: 39
« on: October 29, 2017, 04:01:44 pm »
Hey.
So I’m about to retrofit this alarm kit. Genuine VW parts and looked for all the connections in Elsawin.
However... when I unlock the car the button has full red lightning, also when the door opens. This must be the wire there’s tapped to connector B/pin 11 from central electronic module.
When the light dim when ignition is on or the door is closed the light in the button also disappear? Do you have the button illuminated while driving?
What would make sense to me is if this light were following the rest of interior buttons like mfsw, power windows etc etc..
Also when you deactivate for example the tilt sensor should the light that indicates tilt turn yellow?
EDIT : I can get the yellow light when deaktivated when I press the buttons without ignition..
Would be great if you could write how your button light up :party: And if someone is really a champ maybe even a movie? :D Cars in Denmark didn't come with this stuff so not much help to get on danish forums hehe..
« Last Edit: October 29, 2017, 05:27:30 pm by Christiank »
