Author Topic: Fast road alignment  (Read 1555 times)
Mikey1p
Fast road alignment
« on: October 29, 2017, 09:27:34 pm »
Hi all. Just joined the forum and getting to grips with it. I've got a mk2 Leon tfsi  (shares chassis with mk5)  and looking for a good fast road alignment set up for track.  Any advice would be much appreciated. Thanks in advance
Sent from my SM-G925F using Tapatalk
Offline colesey
  • -Receive: 89
Re: Fast road alignment
« Reply #1 on: October 30, 2017, 05:46:46 am »
Mikey, you’re going to need 1.5 to 2.5 deg of neg camber on the front depending on how road / track oriented you want to be.  Expect inner tyre wear and tram-lining on the more extreme settings.
To achieve this, you will need either superpro adjustable ball joints (which ime give @1.5) or adjustable top mounts (>2). Not sure if you already have either or indeed have upgraded your springs / dampers / arbs.
You will also find that a small amount of toe out instead of toe in will make the car turn in quicker.
