Author Topic: Ticking noise.  (Read 10653 times)
Offline gti turbo
Ticking noise.
« on: February 07, 2010, 11:17:58 am »
When sat at traffic lights yestarday i could hear a ticking noise from the engine sounded like tappets but not sure.
Was just wondering if this is normal.
If not anyone any idea what it could be? :scared:
The problem with the designated driver program, it's not a desirable job. But if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house.
Offline WhiteGTI
  • F-A-S-T
Re: Ticking noise.
« Reply #1 on: February 07, 2010, 11:39:34 am »
How is your oil level?
The GTI engine is pretty tappety sounding to be honest.
The noise you heard could also be the climate system vents moving around, they click and 'tap' all the time!
2006 E46 BMW M3 - 343hp
Offline gti turbo
Re: Ticking noise.
« Reply #2 on: February 07, 2010, 12:48:47 pm »
Oil level fine and with all fans switched off started the engine and was fine until warmed up then started tapping again, :confused: It sounds like a diesel.
Offline BMX
Re: Ticking noise.
« Reply #3 on: February 08, 2010, 09:58:09 am »
sounds like the cam chain and tensioner
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Offline ukdub
Re: Ticking noise.
« Reply #4 on: February 08, 2010, 06:01:46 pm »
Sounds like it to me as well.
GTI Turbo, is you engine code AXX?
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline Sie
Re: Ticking noise.
« Reply #5 on: February 08, 2010, 06:16:03 pm »
sorry for hijack but price do VW charge for fix on this??
Sie
Fettled Laser Blue '05 GTi 5dr
Offline gti turbo
Re: Ticking noise.
« Reply #6 on: February 08, 2010, 11:22:16 pm »
How do i find engine code?
And how much to fix?
Offline ukdub
Re: Ticking noise.
« Reply #7 on: February 17, 2010, 07:30:11 am »
Easiest place to find is on your log book under 'Engine Number'
As for price, not 100% sure.  I know the parts required are less that £100 and the fitting I would guess at about 3-4 hours.  Mine has been like this for over 40k now, keep meaning to get it done though.  Should add that the noise hasn't got any worse in that time, but that doesnt mean its ok to leave.  Will pull my finger out soon and get it done  :grin: :happy2:
« Last Edit: February 17, 2010, 07:35:49 am by ukdub »
Offline Sie
Re: Ticking noise.
« Reply #8 on: February 17, 2010, 08:43:02 pm »
Can they not just tighten the tensioner? or has it gone like that because the chain has gone slack??
Sie
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: Ticking noise.
« Reply #9 on: February 17, 2010, 09:14:20 pm »
Its a belt, rather than a chain...right?  :confused:
Offline Russ_leeds
Re: Ticking noise.
« Reply #10 on: February 17, 2010, 10:22:38 pm »
yeah its a belt. i believe the new tsi engines have a chain, so is much stronger
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline tony_danza
  • -Receive: 112
Re: Ticking noise.
« Reply #11 on: February 17, 2010, 10:47:12 pm »
Have you noticed a smell of almonds?
ACME written anywhere in the engine bay?
Did you buy it from someone called Wile E Cayote?
Sideways yo!
Offline QD MBE
  • -Receive: 102
Re: Ticking noise.
« Reply #12 on: February 17, 2010, 10:48:47 pm »
:signLOL: :signLOL: :signLOL:
Offline ukdub
Re: Ticking noise.
« Reply #13 on: February 18, 2010, 07:27:22 am »
Belt is on one side, the cam chain is on the other.  The chain is just between the two cams on the HPFP side of the engine. :happy2:
Offline Sie
Re: Ticking noise.
« Reply #14 on: February 18, 2010, 07:13:30 pm »
Thought it was, and my noise is coming from the chain side, hopefully they can sort it when it goes in for its next service.
Sie
