Author Topic: Rcd 510 straight swap?  (Read 2201 times)
Offline seanieb
« on: November 04, 2017, 11:55:14 am »
Looking to slightly improve my standard gti stereo as id like the memory card function. Is it a straight swap from the bog standard system?
Offline H18Golf
Re: Rcd 510 straight swap?
« Reply #1 on: November 06, 2017, 03:15:07 pm »
The RCD510 will be a straight swap for your standard (im guessing RCD300) stereo in as much as the fit.  You will need a new CANBus to stop battery drain.  I got mine from @Eddie-NL on here and followed some online guides for fitment.  The stereo is very easy to fit, again have a look online.  The CANBus is a bit of a pain but definitely do-able.
PS.  This is the exact upgrade I done in my car.   :happy2:
Offline dronners
« Reply #2 on: November 06, 2017, 07:42:42 pm »
just a note on my 08 plate car i didnt need a new canbus controller but better to assume you need it.  most certainly will on anything 07 and older
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: November 07, 2017, 11:33:15 am »
08 plate and late 07 won't need an updated CAN Gateway. Even the RNS-510 just needs a GPS antenna that it's fitted above the headunit. It's very easy as well.
