Author Topic: Drivers door lock  (Read 2497 times)
Offline Ant b
Drivers door lock
« on: November 25, 2017, 08:50:20 pm »
Hello my drivers door lock has been abit hit and miss lately and has showed a code on carista for ages,but tonight it went and it’s finally stopped working,the car locks fine but the drivers side won’t unlock by remove,so I’m using the key atm.
Could someone get me the part number please so I can veto e before I strip it all down,it’s a 2005 3door gti reg ks05 fak thanks
red mk5 golf gti ks05 fak,ram air intake,3” downpipe/decat,dv+,bcs rev ll exhaust stage 1 remap.coilovers,whiteline rarb and depo projectors,
Edition 30 front splitter,r32/gti rear,r32 side skirts
Soon to be r tech stage 2
4ndy
Re: Drivers door lock
« Reply #1 on: November 25, 2017, 08:58:14 pm »
more than likely the door mechanism has failed. Changed L and R in the last few months ebay search will get you one for £20  Door skin off.
Offline Ant b
« Reply #2 on: November 25, 2017, 09:11:49 pm »
Are they all the same,can I buy any for the correct side of eBay and it will fit and work
Offline Ant b
4ndy
« Reply #4 on: November 25, 2017, 09:23:19 pm »
 check the ebay description  Pretty sure that the one you need is the same as all golfs from 2003 Message the seller to make sure they send the correct side you need. One or two have a 12 month warranty  :thinking:  UK seller should get to you quicker  :happy2:
4ndy
« Reply #5 on: November 25, 2017, 09:25:37 pm »
Offline Ant b
« Reply #6 on: November 25, 2017, 10:25:31 pm »
If that works are be happy as it’s cheap,everything’s is going wrong with this car,my 02 sensers gone now
Offline thenorthster
« Reply #7 on: November 26, 2017, 03:20:34 pm »
Watch out for the cheap eBay ones - the one I bought was a dud. Better to spend 70-90 on an expensive one than end up paying 200 in labour and VAT to a garage for them to replace...
2005 Mk5, 3 door, tornado red (naturally)
Offline Ant b
« Reply #8 on: November 27, 2017, 01:30:27 pm »
Will this work http://pages.ebay.com/link/?nav=item.view&alt=web&id=142468849124&globalID=EBAY-GB
:happy2: Thatll do  One or two guides on you tube will help
They have just replied saying it won’t fit,yet it says mk5 in the add
Offline Ant b
« Reply #10 on: November 29, 2017, 11:41:26 am »
https://www.ebay.co.uk/itm/VW-Golf-MK5-2003-2009-Driver-Side-Door-Lock-Actuator-Lock-Control-Mechanism-UK/282696852401?hash=item41d20ba3b1:g:LTYAAOSwyzNZ5PNA  As before ask regarding fitment.
Everyone on eBay seems useless,they said itwont fit a3 door as it states hatchback and estate only,it is a hatchback?
The other one I gave my reg and they said what’s this?
Anyone got the part number for a driver side 3door gti
Offline Ant b
« Reply #11 on: November 29, 2017, 11:48:56 am »
I’ve just found one used of a 05 3door gti same as mine but the part number starts with 3d2 and the one on that link says Oem number 3d1 all other numbers are the same
