Author Topic: Low knocking noise - any suggestions?  (Read 6409 times)
Re: Low knocking noise - any suggestions?
« Reply #15 on: January 18, 2018, 09:22:00 am »
That is definitely a symptom of an unhappy MAF.  You can try a bit of MAF cleaner on it to see if it helps.
Another thing you can check is the cam sensor.  Mine was covered in metallic dust.  I popped a new one in and the mpg improved drastically, as did the throttle response.  I recently put a magnetic sump plug in to try and reduce that problem.
Offline Gtcpaul1971
  • Graphite blue 54 plate 5 Dr gti.
  • My Ride: Graphite blue, 54 plate gti
« Reply #16 on: January 18, 2018, 08:25:01 pm »
pudd- how do I fit a cam sensor? Is it easy? Cleaning the maf is straight forward but I am crap at car diy. How much are cam sensors?
Thought id give the maf cleaner a go before buying a new one. Really funny matey that my car seems to have exactly the annoying little things as yours!  :happy2:
Graphite blue 54 plate.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #17 on: January 18, 2018, 09:09:34 pm »
https://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/40-ENGINE-Camshaft_Sensor_Replacement/40-ENGINE-Camshaft_Sensor_Replacement.htm
« Reply #18 on: January 19, 2018, 09:30:15 am »
Yeah that guide covers it, cheers Mij.  Dead easy  :happy2:   Sensor is around £40 with the VAT if I remember, so not expensive for a part that lasts at least 10 years  :happy2:
Other cars with the same problem is good in a way as there is a definite problem.  Isolated issues are a pain in the neck for diagnosis!
Offline Gtcpaul1971
« Reply #19 on: January 19, 2018, 07:05:25 pm »
Right, removed MAF, sprayed the metal part only, let it dry and put it back. No difference! Should I have sprayed in the plastic housing it came out of?
« Reply #20 on: January 20, 2018, 01:09:59 pm »
You spray it into the hole that faces the battery when fitted to the airbox mate  :happy2:
That metal plate is just the backing for the electronics I think.
Offline Gtcpaul1971
« Reply #21 on: January 20, 2018, 06:12:18 pm »
Thanks bud  :happy2:
Offline N44tty
  • Newbie
« Reply #22 on: March 17, 2020, 09:44:40 pm »
Hi guys did anyone get to the bottom of this issue I have the same problem with my s3🤯
New stock clutch kit and dmf but still have the noise
« Reply #23 on: March 21, 2020, 12:17:58 pm »
As per our discussions, ordered one of these to see if it helps.  Well, both sets actually as I'm not sure if my end cap is 79.5mm or 84.5mm!
https://www.darksidedevelopments.co.uk/products/02m-02q-gearbox-input-shaft-shim-kit-and-end-cap.html
Offline Gtcpaul1971
« Reply #24 on: March 27, 2020, 07:41:45 am »
Hi. Mine was the shim. £29 for the part and £50 to fit. All sorted.
