Author Topic: Rear Sping Snappy McBrokenface  (Read 4916 times)
Offline neilw
« on: December 05, 2017, 06:59:12 pm »
Snapped a rear coil spring this morning.
Looking at replacements on Eurocarparts it shows two different Sachs springs for the ed30
Does anyone know which is correct?
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2007/p/car-parts/suspension/suspension-and-steering/coil-spring/?627446100&1&2663fc96e35b72e0bfe0fd88cfedf3246a54acd2&000073
627447020
Or
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2007/p/car-parts/suspension/suspension-and-steering/coil-spring/?627447020&1&eba764c52f0b97cb2161ac3fc146ccfc28248708&000073
Product Code: 627447020
The other option is to get a set of Eibachs on there, but I don't know if I've got time to get the fronts done aswell. There only £94 on a site buycarparts.com (Not herd of them before) Anyone know how long it nornally takes to swap the fronts? I got the rear spring out in less time than it took my wife to cook dinner.
« Last Edit: December 05, 2017, 08:35:59 pm by neilw »
Edition30 #0002 R-Tech Stage2
Offline dronners
Re: Rear Sping Snappy McBrokenface
« Reply #1 on: December 05, 2017, 09:18:23 pm »
i'd factor in a couple hours and bearing in mind you need a multi spline socket ( cant remember size)  and a hub spreader tool to do it.   i think from what i was told one sides driveshaft has to come out of the hub too to make clearence to swing the strut out
Offline neilw
« Reply #2 on: December 06, 2017, 09:57:03 am »
I've slept on it and I think I'll go for the Eibach Sportlines. I was going to lower it at some point next year anyway. I can use my wifes Beetle to get to work for awhile so I don't need to rush. I've got a spline bit, it looks like I'll need a spreader tool.
I'll call over to TPS at lunchtime and order new strut and axle bolts.
Is the bolt in the rear control arm that attaches to the hub single use?
Anyone know the torque settings for these bolts?
Offline neilw
« Reply #4 on: December 06, 2017, 12:27:58 pm »
Thanks Pudding.
Offline neilw
« Reply #5 on: December 06, 2017, 02:09:30 pm »
I've ordered the Eibach Sportlines, they where £140. Picked up all the bolts I need form TPS (£28)
Just need to get the spreader tool now.
Will it cause any major issue driving around for a bit with a lowered backend and standard setup up front?
« Last Edit: December 06, 2017, 06:03:23 pm by neilw »
« Reply #6 on: December 06, 2017, 02:27:40 pm »
Nope.  It might feel different on turn-in with stiffer rear springs (same effect as a bigger anti-roll bar) so watch yourself on wet corners!
Offline GTI8v
« Reply #7 on: December 06, 2017, 07:32:44 pm »
Be aware that top mounts and drop links are prone to seizing / dropping to bits, so you may have to budget for those as well when doing the fronts.
Offline neilw
« Reply #8 on: December 06, 2017, 10:09:11 pm »
Thanks. Fingers crossed I'll be ok, but I'll be prepared! Luckly my wifes not using her car much at the moment so I'm not stuck if I have to wait and get more parts.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #9 on: December 06, 2017, 10:26:27 pm »
I've had sportlines on mine for over 2 years now, they are harsher and I'd recommend sticking em on new shocks
Offline Tazocin
« Reply #10 on: December 07, 2017, 09:04:08 am »
100% this. Had to hacksaw a droplink off the front ARB after the strut end had completely rusted can couldnt be undone. Droplinks were ALMOST worse than all the rest of it. I also had to drill out a top mount bolt as it had seperated from the top mount. My car was at about 110k and 10yrs old so kind of expected tbh.
« Reply #11 on: December 07, 2017, 09:28:59 am »
Interesting.  Do you live near the sea?  Mine all came apart like lego at 110K.
Offline neilw
« Reply #12 on: December 07, 2017, 09:32:12 am »
I'll make sure I use heat and spray. I've got a nice impact wrench which should all help.
I intend to update the shocks at a later date, probably VWR's or whatever they are called now
« Last Edit: December 07, 2017, 09:33:56 am by neilw »
« Reply #13 on: December 07, 2017, 09:48:56 am »
Yeah the RacingLine ones.  They're good  :happy2:
Offline Tazocin
« Reply #14 on: December 08, 2017, 11:02:41 am »
I dont but I'm the third owner so it may have spent some time in the sand and salt. Nothing was unreasonably corroded but I just couldnt get the leverage as the ARB would flex and the car was too close to the ground. That being said I am seeing rust on several of the undercar parts (rear arms are looking dubious) and am replacing them slowly as budget allows and nothing awful given its 10yrs old. Nothing has failed on me yet apart from spring snapping which was pothole related.
The one thing that has worried me is the DSG/mechatronic cover (a flat black painted box on front of gearbox had a load of rust on it when I changed the IC the other day. Sanded it down and applied anti corrosive and painted it over but was worrying. That box was massively worse than any other component on the car, no idea why it was so much more affected.
