Author Topic: Projector lights guide  (Read 3370 times)
Offline GTI DAZ
  • My Ride: Previous: Mk7.5 Fiesta ST, Current: None, future: MK5 GTI
« on: December 08, 2017, 10:13:27 am »
hi all, im looking into retro fitting projector lights, is it a simple plug and play? or will i need coding?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Projector lights guide
« Reply #1 on: December 08, 2017, 11:01:40 am »
Fitting wise its straight plug in. I would definitely get it coded, its only 1 check box.
Ive had 2 depo sets and  recently switched from a HID kit to a LED bulb. Better light output and no need to worry about mounting ballasts anywhere.
Offline GTI DAZ
« Reply #2 on: December 08, 2017, 11:15:59 am »
perfect Raz, thank you, so id be ok to get them, fir them with standard bulbs for now, drive to someone to code them and then get LED bulbs?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: December 08, 2017, 11:40:36 am »
Yes you should be ok, as stock lights dont draw a lot of current compared to HIDs. But the light output on normal h7 bulbs in projector lights isnt any better than reflector headlights
These are the LEDS I bought
http://www.ebay.co.uk/itm/UK-26000LM-110W-55W-H7-6000K-Car-COB-CREE-LED-Headlight-Bulb-DRL-Fog-Lamp-Kit/172678231258
Offline GTI DAZ
« Reply #4 on: December 08, 2017, 11:43:39 am »
they standard fitment? no modding of housing or connector?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: December 08, 2017, 11:50:44 am »
Yep, standard H7 fitment. They might be tricky to fit when the headlamps are on the car. much easier if they are off the car.
Just make sure the projector headlight you get have H7 fitment
Offline GTI DAZ
« Reply #6 on: December 08, 2017, 11:55:24 am »
best place to get them? seen a few on fleaBay for around £200
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: December 08, 2017, 12:11:46 pm »
i know my cousin is after a set at the moment and from what I can see they are currently sold out.
Eurowagens is the seller who I normally buy them from
Offline GTI DAZ
« Reply #8 on: December 08, 2017, 12:31:46 pm »
in stock now @RetroRaz
https://eurowagens.com/headlights-set-projector-chrome-vw-golf-mk5-jetta-mk3/
Offline akbarirfan
  • -Given: 81
« Reply #9 on: December 11, 2017, 02:37:51 am »
Did you go from a 35w HD kit Raz?
All the YouTube reviews show HIDs to be brighter.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: December 11, 2017, 06:28:04 am »
Yes 35w 5000k was the hid kit from hids direct
Sent from my SM-G955F using Tapatalk
Offline Ed30kirk
« Reply #11 on: December 12, 2017, 10:40:48 pm »
What do you have to change in vcds? I only have vcds lite would I be able to do this.?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: December 13, 2017, 08:07:45 am »
You have to tick the box that says xenon without shutters installed. Its either in central electrics or central convenience module.
Not sure if lite version would do it to be honest
