Author Topic: massive rev kicks down - UPDATE - SOLVED!  (Read 1508 times)
Offline GTICZ
« on: December 14, 2017, 06:04:15 pm »
Hi guys,
  im dealing with this problem:
<a href="https://www.youtube.com/watch?v=-EnGCBlq2B8&amp;feature=youtu.be" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">https://www.youtube.com/watch?v=-EnGCBlq2B8&amp;feature=youtu.be</a>
whats happend:
-bad DV and coolant distribution pipe - repaired and cars goes nicely for week
-my battery drained while i left parking lights on for 2hours in cold (since then i thing readiness isnt full 0 )
-after two days, first time i got this problem - 3.500 rpm and massive lag under full load with 3rd gear
but cruising is without any signs of problem, speed over 200km/h no problems. (empty highway in night for test)
-next day same problem, around 3500 rpm huge lag, no fault codes, nothing weird in vcds
-few days without any problems in whole rmp
-yestarday around 2pm i felt little loose of power, then ok and vcds have 004243 fault at this time ... but ... around 4.40am several times exactly like in video on top.. around 5.500 rpm huge lag rpm fall down and get back but there is no fault code for this...
-idle and normal cruising is fine
does someone had this problem?
« Last Edit: January 03, 2018, 06:32:32 pm by GTICZ »
Offline GTICZ
Re: massive rev kicks down - edited
« Reply #1 on: December 17, 2017, 03:13:55 pm »
anybody?  :thinking:
Offline GTICZ
Re: massive rev kicks down - UPDATE
« Reply #2 on: December 30, 2017, 08:30:19 pm »
News..
  i have NO fault codes.. tried another MAF, PCV.. still massive lag..
logs:
https://files.fm/u/bbnprbwd
« Last Edit: December 30, 2017, 10:20:44 pm by GTICZ »
Offline GTICZ
Re: massive rev kicks down - UPDATE - SOLVED!
« Reply #3 on: January 03, 2018, 06:33:37 pm »
SOLVED: Crankshaft sensor was faulty.. from 5500 daily till 3000rpm max...
