Author Topic: Potential fault - GFB DV+  (Read 6589 times)
« on: December 15, 2017, 11:41:05 am »
Chaps, Chapesses and Transgenders......
I just wanted to alert you to a design flaw I've discovered with the GFB DV+.  Please check yours next time you service it.  Gently pick at the edges of the orange silicon pad to feel if it's separating from the brass piston.  Don't go at it full gorilla, just give it gentle probing.  Everyone loves a good probing, right?
For reference, mine was bought in 2014 and is genuine, and the pad has come away from the piston completely in 2 places.  I think it's a vulcanizing problem and could do with improving.  I have alerted GFB Australia.  You may or may not care, just thought I'd mention it because if that pad comes off completely and finds it's way into Mr Turbo's throat, I don't think he will like that very much.
Offline 19TW80
Re: Potential fault - GFB DV+
« Reply #1 on: December 15, 2017, 12:04:03 pm »
Interesting, and looking forward to hearing what GFB has to say in response. Incidentally, I've had a look at GFB's site, and as far as I can see there's no detail explaining exactly what it's 'limited lifetime warranty' is i.e. how long after date of purchase the product is warranted for.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: December 15, 2017, 02:05:27 pm »
Doesn't surprise me that it's come away.
Their sh*t response to your query is disappointing though.
They should sell the brass piston as a replacement part but then that goes away from their "fit and forget".
Did you go back to Rev D or G?
Offline Octoparrot
  • -Receive: 102
« Reply #3 on: December 15, 2017, 03:34:17 pm »
How many miles have you done since it was fitted?
« Reply #4 on: December 15, 2017, 03:49:30 pm »
I fitted it at 80K miles I think.  It's now on 118K.  That isn't too bad compared to the lifespan of a Revision G valve I suppose, but GFB kind of market it as the last DV we will ever need. Not quite, it seems.
It doesn't affect the sealing under boost, but when you back off the gas and it dumps the waste boost, the turbulent air pressure is eventually going to rip the pad off completely.  Well, it did on mine...in 2 places.  At stage 2+ tuning, that's 25+psi of pressure we're talking about.  On a KO4 engine, that pressure will push the separated along the dump pipe until it eventually find it's way into the turbo.
I have a revision G in it at the moment and the throttle response is a bit lazier as a consequence!
I thing I did notice is the surface the silicon pad is bonded to is completely smooth.  Surely some kind of knurled surface is better for adhesion?
I should add I have not cleaned mine with any harsh chemicals, just a dry cloth.  But regardless of that, a properly bonded component should come away like that in the first place.
Offline ghuk
« Reply #5 on: December 15, 2017, 05:11:05 pm »
Hi Pudding
Thanks for the heads up. I had a GFB Diverter Valve+ fitted by AMD Tuning just over a year ago as the OEM part was shot. Therefore will get my garage in Leighton Buzzard to check it every service.
Can you keep us updated with any response? Maybe a bit of pressure on social media from a few of us might do the trick if it's stone walled.
Crikey, the last thing I need is that part failing and causing futher 'issues'. I've spent over £3k so far in 2 years of ownership getting my car up to scratch....  :slap:
2005 Golf GTI Mk5
« Reply #6 on: December 15, 2017, 05:56:30 pm »
Will do!  I hope this hasn't come across too dramatic and alarmist.  If it's happened to me, it's sure to happen to someone else...unless I am the unluckiest man in the world and got the one and only dud  :grin:
Besides the silicon pad thing, I didn't find it to be fit and forget.  Occasionally the piston would start binding, causing part throttle surging.  I had to strip it down, clean it and reoil it and then it was good again.  Had to do that every 6 months or so, or when I could feel the part throttle getting funny on me.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #7 on: December 15, 2017, 06:05:00 pm »
If anything Kev you've done us all a favour for the heads up mate appreciated
Or are you just "trolling" again
« Last Edit: December 15, 2017, 06:23:41 pm by MIJ_JAGGER »
Offline ghuk
« Reply #8 on: December 15, 2017, 06:24:03 pm »
Very interesting that you mention this Pudding as I've had the same impression with mine on a couple of occasions, almost like the piston was sticking. Hmm.........
I'm not technically minded but potentially can you not re-attach the silicon strip with some sort of bonding agent? Just a thought....
2005 Golf GTI Mk5
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #9 on: December 15, 2017, 08:57:21 pm »
Cheers for bringing this to the forum's attention Kev.
I don't have any experience of the GFB valve myself - it's one of those things nearer the bottom of the never ending list for me. Probably because I've had no problems running a rev G at decent boost levels for a while now. I've never found it lacking in terms of boost response, so it's probably a case of 'if it ain't broken...' in my case.
That said, there are loads on here running the GFB. And undoubtedly loads thinking it is that fit and forget part we're led to believe. Hopefully if there is a design flaw that's affected all the valves it's something that can be acknowledged and resolved by GFB.
Keep us updated mate.
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« Reply #10 on: December 15, 2017, 09:06:22 pm »
I had a gfb+ fitted prior to mapping with the tte420.....and it got taken off straight away due to issues ( not by me either) and refitted with a rev g valve and fixed my boosting issues so the people raving about them must be the lucky ones which have one what actually works
I'm not convinced by these I've had 3 now and they've made the car feel different....
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: December 16, 2017, 12:43:48 am »
Would you say the pad was fully stuck on before fitting or did you not check at the time of fitting and only decided to check out of curiosity ?
« Reply #12 on: December 18, 2017, 10:32:57 am »
It's been in and out of the engine about 10 times in 3 years, either to swap to a G and D for comparison, or just for maintenance.   On each occasion I gently picked at the edge of the rubber pad just to check for bond integrity.  Considering the extremes of temperature, moisture and oil vapour, not to mention 25-30psi boost flowing through it, it just seemed prudent to check it wasn't detaching.
The last couple of checks the bond had let go very slightly, but it didn't concern me at the time.  The last check and what prompted this thread, the separation had spread drastically.  Once that much air pressure gets under the slightest lift in the bond, well, we all know what tornados do to roofs!
Brett from GFB ('Go fast Brett' on youtube) came back to me and was extremely pleasant and civil about it.   He said they improved their tooling and bonding process in 2014 and suggested mine was an older model that pre-dated the improvements.  Mine is the only failure he's seen out in the field but alluded to it happening in testing prior to the 2014> changes.  I wasn't seeking compensation or to kick up a big stink about it, merely to pass on some customer feedback and he was grateful for that  :smiley:
Anyway, that mega glue I used in my other thread seems to have done the trick, but please do check yours chaps when you get the opportunity.
As for the performance of the DV+, since switching to Revo 2+, I can't say I notice any improvement with the Revo Intake. Perhaps a very slight sharpening of the throttle response.
When I had a custom map with the factory air box, that's when I really noticed the DV+.  It was way more responsive than the OEM diverter valves.   I don't understand why, but it just worked the best.  The DV+ does seem to cause some part throttle surging/shunting at urban speeds with very light throttle.  I think that's because the OEM valve is very keen to dump ALL of the air when coming off the throttle, whereas the DV+ keeps some pressure in the manifold, which I guess some ECU tunes don't account for?  Not sure.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: December 18, 2017, 01:25:18 pm »
Thank you for reply mate, really appreciate it.
Will get GFB out for checking and whilst there I'll pop the Rev D in and drive it around for a while to see how that area up with boost as I've never had a normal working dv in mine since my original was torn and losing mega boost.  :happy2:
Also didn't think these GFB were fault proof as that rubber diaphragm was always going to come off at some point!.
« Reply #14 on: December 18, 2017, 01:39:25 pm »
No worries mate!  Having a decent DV makes a big difference in these engines!
