Author Topic: Potential fault - GFB DV+  (Read 6594 times)
Offline Bernhard30
Re: Potential fault - GFB DV+
« Reply #15 on: December 19, 2017, 11:03:42 pm »
Hi guys,
Recently fitted a GFB DV+..only just bought it from AKS so I guess it's the later version.
This was put in to replace a split diaphragm on my old version which was looked to be causing a check engine light. From memory the fault code PO277..'running too lean at idle'.
Bit of a strange question but does the DV+ work just like a standard DV and so would not prompt a CEL on the dashboard. As even with DV+ in use..the car lasted only about 20 miles before the engine light came on again..so the fault still exists..but wanted to check.
Feels a bit like a boost leak/air leak perhaps ..but just wanted to check from those with DV+ experience.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #16 on: December 20, 2017, 07:59:32 am »
DV+ should not cause an EML and would not cause a P0277 code, which is something to do with injector 6 (which we dont have!) I suspect you mean the P2187 code? Bank 1 too lean at idle?
You can occasionally get the code for a mechanical fault with the valve due to the way the DV+ works, but it would not put the EML on
Sounds like you still have a leak somewhere, as a fault DV wouldn't cause that error anyway.
http://wiki.ross-tech.com/wiki/index.php/18619/P2187/008583
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #17 on: December 20, 2017, 10:15:30 am »
Hi guys,
Split in your turbo house around the connection point is my first guess
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #18 on: December 20, 2017, 06:11:15 pm »
No worries mate!  Having a decent DV makes a big difference in these engines!
It definitely does mate  :happy2:
Offline Bernhard30
« Reply #19 on: December 20, 2017, 06:26:28 pm »
Hi guys,
Thanks guys. Will check it.
Correction to my earlier question..my fault code was/is P2177.
