November 24, 2024, 02:41:25 pm
All Things Mk5
How to Guides / Troubleshooting
Strange rattle on cold starts
Topic: Strange rattle on cold starts (Read 4033 times)
stroudy007
December 17, 2017, 03:03:40 pm »
I'm getting a strange rattle/clatter on cold starts which increases with the revs, goes away after about 30 seconds. No dash lights on or fault codes. This video (Not mine) is exactly what I'm hearing) Anyone had this issue? Cheers!
d4t_pom
Re: Strange rattle on cold starts
Reply #1 on:
April 05, 2019, 05:28:33 pm »
Check the cam chain+tensioner or it is the chain+tensioner on timing belt side connected to the oil pump.
Ripstop
Always Involved
-Given: 1
-Receive: 11
Reply #2 on:
April 17, 2019, 09:17:38 am »
Sounds a little like oil starvation on the top end at engine start and cams aren't fully lubed. Do you get the same when starting after its hot? Also I would drop the sump and check the strainer.
Stage 1 2007 Black Eddy #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic. The car is *always* work in progress fixing and upgrading things.
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Reply #3 on:
April 17, 2019, 12:10:38 pm »
A worn VVT adjuster can get a bit rattly on a cold start-up.
All Things Mk5
