Author Topic: Engine temperature  (Read 2030 times)
Offline Ria73
Engine temperature
« on: December 17, 2017, 08:10:06 pm »
Hi Guys
Can anyone help or advise on running engine temp on a GTI mk5
It sits around 50 I’m pretty sure it was sitting around 90 previously, is this a thermostat problem? And are they easy to change?
« Last Edit: December 17, 2017, 08:11:47 pm by Ria73 »
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
Re: Engine temperature
« Reply #1 on: December 17, 2017, 08:29:09 pm »
Yep, seems like a thermostat problem.
Might be worth checking these videos:
« Last Edit: December 17, 2017, 08:31:07 pm by teo_parvu »
Offline Ria73
« Reply #2 on: December 17, 2017, 08:37:51 pm »
Thank you, very much appreciated 👍🏻😁
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: December 17, 2017, 09:03:57 pm »
It’s your thermostat.
Use the search function for more info
Manual has a main and an inline which are expensive and cheap to fix respectively.
Offline mattkgti
  • Amateur MK5 Golf GTI Enthusiast
« Reply #4 on: December 20, 2017, 05:32:47 pm »
Hi Guys
Yes mate it should be your thermostat. Just had mine replaced and fixed the problem.
Matt.
Offline probedb
« Reply #5 on: December 22, 2017, 06:16:19 pm »
Just thinking mine may need doing. Saw the temp head towards 90 then dropped down to 50. Will keep an eye on it over Christmas and get it sorted in the new year. I only noticed it because I don't want to put my foot down too much unless it's warmed up :)
