Author Topic: Powerfolding mirrors  (Read 3999 times)
willni
« on: December 22, 2017, 06:34:29 pm »
Yep another question about the retrofitting of powerfolding mirrors.
Trying to work out which part number to go off for the door/window control module I'll post a picture of my current one below, I have two from a golf with powerfolding mirrors but if it saves me from removing them it would be great.
willni
Re: Powerfolding mirrors
« Reply #1 on: December 22, 2017, 06:35:23 pm »
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #2 on: December 22, 2017, 06:43:10 pm »
The 1K0 on the silver motor bit
Mine were M too, swapped over for N
« Last Edit: December 22, 2017, 06:44:41 pm by MIJ_JAGGER »
willni
« Reply #3 on: December 22, 2017, 06:46:24 pm »
Brilliant thank you, I’ll just swap it out rather than risk a 50/50 on the N working
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #4 on: December 22, 2017, 06:48:13 pm »
N was plug and play on mine, bit of coding needed because they were off a 5dr
willni
« Reply #5 on: December 22, 2017, 08:09:31 pm »
@MIJ_JAGGER what errors does it throw up being 3dr vs 5dr, mines a 5dr so just wondering what to expect?
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #6 on: December 22, 2017, 08:28:05 pm »
It had an error about something to do with one of the rear doors. I coded it to 3dr and cleared the fault and it was all good
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: December 22, 2017, 09:45:57 pm »
Make sure the power folding modules are M N or Q. If they are K or L then they will not work in your car
Sent from my SM-G955F using Tapatalk
Offline Juliand
« Reply #8 on: December 26, 2017, 01:52:24 pm »
Don't bother wasting your time and effort............They're almost useless and only move in about an inch. I thought mine were faulty, but seems that is all they move. Unless you're really short on space onto your garage, I really wouldn't bother, but of course your decision..............
Offline Christiank
  • -Receive: 39
« Reply #9 on: December 26, 2017, 07:42:26 pm »
When you say modules and type these "M, N, Q" you mean this should be the partnumber for the window power regulator right?
The black electronic box are different partnumber
GEN 3 MOTOR with MAX modules are N and Q
GEN 2 MOTOR with MAX modules are L
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: December 27, 2017, 01:41:16 am »
Yes the part number on the window regulator.
Reason i said M N or Q is because his current module is M, which means gen 3. If he was to fit a K or L then it won't work because those are gen 1.
willni
« Reply #11 on: December 29, 2017, 09:52:41 pm »
By not work do you mean not work at all? As I've fitted the set and they fold but not working correctly, the drivers door doesn't actually take the code either, but I think this is an L as you said it so this could be why but it does fold and light up etc.
willni
« Reply #12 on: December 29, 2017, 10:07:31 pm »
Vag number for passenger - 5k0 959 702A now working with coding 0004791
Driver part no - 1T0 959 701 G
With coding 0000679 would take the other coding and not working
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #13 on: December 29, 2017, 11:59:43 pm »
The pins on gen1 door wiring is different to gen 3. So the pin for power for example will be in a different location if you went with a door module that's different to your current door modules generation
You can repin everything, i know SI-R32 has electronic diagrams of what each pin does etc.. Ive been down that path before and it got messy lol as the buttons on my door card didn't work. So just ended up reverting back to stock mirrors.
willni
« Reply #14 on: December 30, 2017, 09:01:00 am »
Thanks, at this point I’ll just source a new module since the other side is fully installed and working, dont suppose you have a spare module?
