Author Topic: Replace spark plugs recommendation - every 15-20k  (Read 3427 times)
Offline neg
  • gone old skool
« on: December 29, 2008, 11:16:34 pm »
VW replaced the spark plugs on the 2.0T every 40,000miles, if your remapped I would highly recommend as preventative maintenance you swap the plugs every 15-20,000 miles.
I was getting a random multiple missfire at high-ish speeds during WOT in 5th/6th, everything seemed fine in the lower gears.  I did the obvious diagnosis with coilpacks which didnt fix it so went onto spark plugs - although the one's in there having done only 15k miles!  Anyway swapped and now the car seems to be running fine again with no hiccups so far.
All 4 removed plugs look the same and dont appear to look 'bad' in any way.
FYI, plugs are £9.50 + vat each from VW
Re: Replace spark plugs recommendation - every 15-20k
« Reply #1 on: December 29, 2008, 11:29:39 pm »
Cheapish fix then Neg  :happy2:
Sound advice though as the engine will be working harder than the consumables were designed for.
« Reply #2 on: December 29, 2008, 11:29:53 pm »
JKM recommended I change plugs every 20k miles because my car is remapped. Standard Mk5 GTI VW plugs are fine.
[neg - How's your turbo issue?]
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: December 30, 2008, 08:31:46 am »
Good advice  :happy2: cheers
Red ED35 5dr DSG
BLOG | BUILD
Offline The wheel man
« Reply #4 on: December 30, 2008, 09:27:07 am »
Good call.  After reading ive checked that mine were changed at my 40k service and they were not!!!  Hmmmmmm
APR cat back, ECS Insert
Offline ukdub
« Reply #5 on: December 30, 2008, 01:39:23 pm »
Same thing happened to me as well.  Good advice  :happy2:
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline cmdrfire
    • Commander Fire - my blog
« Reply #6 on: December 30, 2008, 03:14:58 pm »
Replace my plugs every 20k, and my coils every 40k (had them done a bit early at my 77k service). Oil every 5-8k and DSG fluid every 30k :P
She's an expensive girl... even the gf isn't as bad as baby :P
Offline neg
  • gone old skool
« Reply #7 on: December 31, 2008, 11:10:31 am »
Still questioning it, made a few changes - plugs, filler cap etc so need to get it checked out again and do some logs in the new year.
Offline WhiteGTI
  • F-A-S-T
« Reply #8 on: December 31, 2008, 02:53:18 pm »
Good advice Neg!
I will look into this myself soon!  :happy2:
2006 E46 BMW M3 - 343hp
